First off hopefully this is in the right section!!! Ok all you pro-touring and restoration gurus!!!!!!!!!!! I have hit a wall and I'm just getting started. I have a 70 chevelle that I have in a million pieces right now. It's gonna be a mix between pro-touring/pro street your typical BBC/t400/12 blt car to beat the heck out of on the street and the track. I'm as everybody else on a budget so I'm not dropping 30-40k in it at one time but I really could use some input on which direction to go in first. I have to replace the full quarters, (which I have) deck filler panel and patch the front lower fenders. Depending on what I find out next week when I get back in from working out of town. I plan to sand the top and doors to see how bad they are and replace the skins if needed. Now I have already pulled the body off once to clean/paint the frame and bottom side of the car. I have decided to make some changes to the frame, I plan to purchase the K-kit from HPC and the box kit for the rear frame portion from ABC performance just because I think not only will it strengthen the frame but improve the looks. I had used (don't laugh) Rustolem high performance semi gloss black rattle can paint on the frame which surprisingly really looks and holds up great. I want to powder coat it and the suspension the same low gloss black the Roadster Shop used on the burgandy 66 chevelle posted on here a while back. I guess now that I have rambled on and probably have everybody scratching their heads. Since I'm not one of the big shops and have a unlimited budget, I'll be dropping about 3-4k at a time. Should I work to get the frame and suspension done first or complete all the body work first before worrying about the frame?? I've made a list of the parts I have and some of the parts I plan to purchase in the near future to give you an idea as to where I'm headed. Thanks in advance for any help and input.
Chassis, suspension and wheels:
1) HPC K-kit (need)
2) ABC rear fame box kit (need)
3) Powder coat or paint
4) Speed-Tech front a-arms (need)
5) Jegs adj upper and lower control arms (have)
6) QA1 adj shock 4 corners (have)
7) Wilwood or Baer brakes (need)
8) Ricks stainless gas tank (have) Thanks Marcus!!!
9) Aero motive a1000 fuel pump and filter (have) Thanks again Marcus!!!
10) Rons Alumn radiator and fans (have) Thanks again Marcus!!!!
11) 12 blt rear end (have)
12) Wheels not sure on yet thinking on weld v-series 17" fronts and 18" rears
( I have 15x 4 and 15x10 centerline telstars with 325/50 DR's now)
Paint and Body:
1) Pretty much look like a stock 70 chevelle with a 4' fiberglass cowl hood
2) Paint factory SS look with some suttle changes
Interior:
1) Stock SS look with a rider friendly roll bar (if there is such a thing) LOL
And by the way if anybody has a decent set of factory SS bucket seats let me know.
Motor and Tranny:
1) Pump gas 468 bbc with balanced stock internals, Probe pistons, hyd roller set up, steel 049 heads with a ton of port work and a little bit of giggle juice just in case that red light is a little further away than I thought. LOL
2) T400 with a Hughes 3500 stall
So hopefully this give you an idea which direction I'd like to be heading instead of in circles!!!! LOL
