Old 11-26-2012, 01:01 PM
blazincopper's Avatar
blazincopper blazincopper is offline
Default L76 G8 high mount alternator bracket-which one do I need?
I am putting a L76 6.0L engine out of a 2009 pontiac G8 into my 67 Camaro. I need a bracket to relocate the alternator to the upper passenger side. From what I can tell, my pulley setup is the same as the LS3 08 and up Corvette setup. Is this correct? If so, is it better to use a stock vette bracket or an aftermarket one.
Thanks in advance
Old 11-26-2012, 08:39 PM
Ron in SoCal's Avatar
^ Not an expert in year specific Vette bracketry but I think you're incorrect? Unless you're Aussie or Brittish the Vette drive puts the Alt on the high, driver side.
http://paceperformance.com/c-142691-...rive-kits.html
Ron in SoCal
69 Camaro in progress
Old 11-27-2012, 04:16 AM
Wow I completely screwed that up. I meant to say the upper driver side. Sorry for the confusion - no wonder I didn't get many replies
Ok - same question but alternator on the driver side
Old 11-28-2012, 12:12 PM
heinz57 heinz57 is offline
Check out Holleys new brackets....same as vette....but....uses truck alt...save u a bunch
Old 12-02-2012, 02:56 PM
shawnvan shawnvan is offline
I just used the Holley bracket check it out it fits vett f body and truck all measured off the crank pulley. The web site has all the measurements but beware to order spacer kit if you aren't using corvette crank pulley. You will also need to change to a vett steering pump.
