Old 02-07-2013, 07:01 AM
Revved's Avatar
Revved Revved is offline
Default Best textbook definition for "Pro-Touring."
What is your best definition for "Pro-Touring?"
I'm doing website updates and wanted to integrate a definition but I haven't found a good text blurb online that I feel really encompasses what Pro-Touring is. Most definitions only define it as only muscle cars, or only expensive professionally built race cars with license plates... but Pro-Touring is more than that.
I'm going to be sitting down and writing one that I'll post up but I wanted to hear from other guys that are living the life.
Old 02-07-2013, 07:06 AM
coolwelder62's Avatar
Pro-touring,See What Mark Stielow Does,then do the same.
Old 02-07-2013, 07:24 AM
Revved's Avatar
A few quick thoughts....
Pro-Touring:
A style of modifying vehicles mechanically, structurally, and visually for increased performance, comfort, durability, and style with the intention of driving in a wide range of environments.
A style of modifying vehicles with modern electronics, high performance suspensions, engines, and styling with the intention of driving them in environments ranging from street use to high performance competition.
A style of integrating modern electronics, structural modifications, high performance engines, suspensions, wheels, brakes, and styling to create well rounded vehicles with the intention of driving them in conditions ranging from daily street use to high performance competition.
Originally Posted by coolwelder62 View Post
Pro-touring,What Mark Stielow,then do the same.
Good point... I should go look through his build book to see if there is a good definition in there.
Old 02-07-2013, 08:34 AM
dontlifttoshift's Avatar
It might be easier to answer this question. "How long is a piece of string?"
Donny
Old 02-07-2013, 09:18 AM
ccracin's Avatar
ccracin ccracin is offline
The length is the square root of the square of half the length multiplied by 2!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 02-07-2013, 09:55 AM
Revved's Avatar
True... but if you don't know where you are... how do you know where you are going? Pro-touring is fluid concept which is likely the reason why there is no "textbook" definition per-se.... I'm just trying to put some words to it that describe it but don't limit it.
Man.. that is deep.
Old 02-07-2013, 10:43 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
That is such a vague question, but the answer is probably less than Steilow's string.
Old 02-07-2013, 12:50 PM
Bucketlist2012's Avatar
Bucketlist2012 Bucketlist2012 is offline
My Car is better than it was before , and not where I want it yet...
Luck is the meeting of preparation and opportunity
Pro Touring 71 Z/28 in training
Soon to be crazy
Old 02-12-2013, 09:05 AM
hp2 hp2 is offline
Pro-Touring:
Kind of generic, but all encompassing.
This infers that it is applicable to older vehicles since you are putting "modern" touches on things. This also means that eveantually things become outdated and require regular updates to maintain its modern status. In most of our cases, these definiations are probably very accurate since we are predominatly starting with pre 1975 vehicles.
However, if you take a 1990s vehicle which already has strut type suspension with decent geometry and you update it, is it still pro-touring?
Does converting newer 4 banger or 6 cylinder cars to V8 power constitute pro-touring if they already have all the amenities but not the power?
Is there a difference between a "Touring" build vs a "G-machine" build?
Old 02-12-2013, 09:17 AM
Bill Howell Bill Howell is offline
Site Sponsor
There, I feel better now! BTW, just checked ebay and obviously their definition by the cars listed as pt is as follows
1. cut springs
2. TT2 wheels
anything above that is just fluff, a waste of money and really necessary.
Bill Howell
www.americanstreetcarseries.com
