Old 02-09-2013, 03:42 PM
headcase headcase is offline
Default 69 fastback mustang weight Q:
Hello,
Just curious about what weight the 69 fastback can be brought down to. I know the cobras are 2500lbs or so, I've heard XV motorsports in full trim bring their 71 cuda to 2800lbs, can the mustang come around the 24-2600lbs mark without looking like a race car with plastic windows, no interior etc.
Old 02-09-2013, 03:56 PM
My '65 Fastback track car weighs 3015 pounds -- it's as gutted as a car can get -- and has Lexan front and rear windows and no side glass what-so-ever... no carpet - no interior - not even door panels (except aluminum covers)
Old 02-09-2013, 04:22 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
If you don't mind, can you refresh my memory as to what engine is in it? Even iron block 302s are pretty light engines (comparatively). I'm kind of surprised it weighs in at 3000ish and not closer to 2800lbs. I'm only surprised because now I'm worried my little Mustang with a full interior will weigh almost as much as half of Rob's Torino.
Old 02-09-2013, 04:39 PM
GrabberGT's Avatar
So subtle I almost missed that.
Chris
Its not a Vega!!!!
Old 02-09-2013, 04:57 PM
Matt....
Only for YOU --- would I leave my couch.... put on some shoes - go down to the shed -- find the packet for the Ford -- rummage thru all the paperwork - get the weight sheet - come back to the house - find an SD Card - scan the sheet - load the SD card into the laptop - convert the file - save it to the desktop - import it to iPhoto - export it to Photobucket..... post it on Lat G -- go back down to the shed - put away the paperwork...
Muttstang has a Ford R code block.... 355.6" cubic inches of Iron ---- with aluminum heads....
Old 02-11-2013, 06:24 AM
Bryce Bryce is offline
Matt....
and you go that all done in 35 minutes!
Old 02-09-2013, 05:24 PM
Originally Posted by ratman67 View Post
thats without you being in the car correct? if so why is the l/f so much heavier than the r/f???
'Cause it is....
I didn't do any of the set up - it's just the paperwork that came with the car.
Old 02-09-2013, 06:09 PM
'Cause it is....
I'd bet you all you have vs. what I have that it's with driver and you should get your car back on the scales to get the cross weight right.
Old 02-09-2013, 05:53 PM
Sieg's Avatar
Sieg Sieg is offline
Stuff like: Steering column, dash cluster, pedals, master cylinders, booster, steering linkage, additional cage reinforcement, etc.?
Old 02-09-2013, 05:59 PM
FETorino's Avatar
FETorino FETorino is offline
GW doesn't that car still have a steering box and center link. The box alone ads some heft on the drivers side.
Rob in SoCal
