Old 04-01-2006, 10:58 AM
ka67_72 ka67_72 is offline
Default Beading the 335's
The only place in town I could convince they could mount my tires couldn't get the 335/30/18s to bead. They didn't charge me for mounting the fronts or halfway mounting the rears. I brought them home, put a ratchet strap on them and they're holding air but not beading completely on the outside. I've never delt with a competition tire so I stopped adding air at 60 psig. The sticker says not to go past 44. The tires are toyo proxes ra-1's. Do any of you have experience mounting these things?
Thanks,
Kevin
Old 04-01-2006, 12:09 PM
Blown353 Blown353 is offline
I would suggest the starting fluid / lighter fluid trick, but it scares the crap out of me every time I see it used to seat slicks at my friend's shop...
1969 Chevelle
68protouring454's Avatar
it can be dangerous, what kind of wheels?? if they are 3 peice or one peice forrged give them some more air but it is best done in a cage so if something comes apart
jake
Old 04-01-2006, 01:26 PM
ProStreet R/T ProStreet R/T is offline
How big of an air supply do you have?
I've always just sprayed the tire and rim with wd40, and blasted them with a big hit of air (core out of the valve stem).
What wheels are you using?
Old 04-01-2006, 02:17 PM
RaceMan's Avatar
RaceMan RaceMan is offline
If you have some time try moving the tire on the rim a few times put some good soap on the bead . In extreme aplications we've had to heat the tire up with a space heater or something of that sort and keep the wheel cool. Some times it just takes time and a bit of effort, good luck
SPEED IS ALL YOU NEED !!!
Old 04-01-2006, 04:32 PM
The tires are sealed they just won't finish going on the outside of the rims. I have cast Z06 Motorsport wheels.
Kevin
Old 04-01-2006, 05:51 PM
quadfather quadfather is offline
i also had trouble with mine . i took them to a shop that had a paint oven and they heated them up it made it much easier. try getting them warm.
