Old 04-19-2013, 11:25 AM
canrc canrc is offline
Default Reverse Lockout
Just wondering how you guys have your reverse lockout wired in? I have been told to wire it to my brake lights or a toggle switch.
Thanks in advance!
_________________________
- Raj
'69 Camaro - Current Project
https://lateral-g.net/forums/show...ighlight=MAX-G
Old 04-19-2013, 06:48 PM
glassman's Avatar
glassman glassman is offline
Wired mine into the brake light switch, until I can find a better lead. If I am going fast in 6th gear and hit the brakes and down shift I could accidentally throw it into reverse...
Old 04-19-2013, 07:08 PM
I was thinking the same thing -- just looking for other options, I don't know how/if I can wire it into the ECM.
- Raj
Old 04-19-2013, 10:10 PM
CarlC CarlC is offline
It can be used with the ECM and programmed accordingly.
http:www.vaporworx.com
Old 04-19-2013, 10:27 PM
Thanks Carl -- would you happen to know what the pin out is from the ECM?
- Raj
Old 04-22-2013, 02:09 PM
David Pozzi's Avatar
Here is a stand alone module I'm going to try: http://www.accutach.com/Pages/OSSVSS...ckoutUnit.aspx
http://www.PozziRacing.com
