Closed Thread
Old 04-20-2013, 03:33 PM
jwcarguy jwcarguy is offline
Banned
Default T56 Magnum TR6060 McLeod Offset Shifter Slik Stick
Bought this shifter from another member here, but plans have changed and it is up for sale
never used it, just mock up
This is the original ad desc: http://www.pro-touring.com/showthrea...tick&highlight=
this is a t56/tr6060 Mecleod Slik Stick shifter.
This is the exact model here in this thread.
left 1 inch, back 3 inch.
http://ls1tech.com/forums/conversion...68-camaro.html
They are pretty detailed in this thread.
You really can't look up the shifter on Mcleod site...
http://www.mcleodracing.com/categories/Shifters.mcl
$225 shippedSOLD!!
Old 04-21-2013, 05:21 AM
turbo corey turbo corey is offline
will this fit on a ls1 camaro t56 and will it fit the 69 camaro stock center console?
Old 04-21-2013, 06:53 AM
Banned
Corey,
I can't say for sure, but from what the member told me that it fits the T56 magnum , TR6060 trans
I have seen some use the mid mount position on the LS1 t56 and mod the shift rod (to move the shifter location)
He had it in a 67 Camaro , so the console location should be close?
Old 04-23-2013, 08:42 AM
geberhard's Avatar
geberhard geberhard is offline
Jeff, I am interested, however from what I measured last night looked like I had to move the shifter 3 inches forward (I know weird) instead.
I believe the base is indexed and can only be installed one way, but I am wondering if the center can be flipped, i.e. remove pin and rotate?
I am loading te frame and powertrain this week, and have a couple adjustable holes on the adapter plates, so may need to wait until I get the engine and tranny in.
Gui
Old 04-23-2013, 09:00 AM
Banned
Gui
I will check when I get home
But I think that you can just unbolt the shift lever and "clock" it 180 degrees
I will look at it better after work
Jeff
Old 04-23-2013, 09:30 AM
geberhard's Avatar
Jeff thanks that is what I am thinking
Gui
Closed Thread
