Old 05-14-2013, 08:29 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default 2 Piece Main 383 to LT1 T56 Need help Fast!
If I get the Flywheel that mates the early SBC's to the LT1 T56 I would end up running the LT1 clutch setup correct? Im in a bind because Im trying to snag a tranny/clutch setup in the next hour or so off flea bay. If the LT1 RXT clutch will fit my application I'm going to drop the hammer on it. Thanks in advance, Kevin
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 05-14-2013, 09:13 AM
With the conversion flywheel a standard small block clutch and disc (26 spline) can be used.
Old 05-14-2013, 09:22 AM
NorCal72's Avatar
Thanks for the response. So the early style (2 piece) SBC and the LT1 clutch will bolt up the same to the conversion flywheel? I know it needs to be the 26 spline. Forgive my ignorance, I just don't have the experience with the manual setups.
Old 05-14-2013, 09:37 AM
Yes, with a conversion flywheel like the Centerforce 183-700107 They are the smaller 153 tooth ring gear so a starter swap might also be needed depending on which starter you have now.
Old 05-14-2013, 09:51 AM
NorCal72's Avatar
Great, thanks again Jody!
Old 05-14-2013, 01:46 PM
rchaskin's Avatar
rchaskin rchaskin is offline
You must use LT1 style clutch.
93-97 Camaro Only.
