Old 05-14-2013, 09:30 AM
Firebird-Geek Firebird-Geek is offline
Default GM vs Reproduction Door Hinges - HELP
INFO:
67 Firebird
I know many say to rebuild the hinges you have because the aftermarket are not very good. But my hinges were in VERY bad shape and possibly bent.SO I am kind of forced to use aftermarket hinges.
Question: Is there a certain part, area or item I should be concerned about? Is there a way to rebuild the aftermarket hinge to make it as good as a GM? What should I get... parts?
I would rather rebuild the hinges now, than later when the car is put together and I have to deal with paint and fitment.
Here is what I have:
Lower Hinges is suppose to be a "GM Restoration Part" and does look like it is a rebuild factory hinge. Are these OK? area of concern?
Upper Hinges are reproduction: I do see they use some sort of plastic bushing rather than a brass bushing like the factory hinge. Should I replace these right away with brass? or is plastic just as good?
1967 Firebird Convertible
Jarrod
My Build:
https://lateral-g.net/forums/showthread.php4?t=32878
Old 05-15-2013, 01:52 PM
makoshark makoshark is offline
Send them back! Reproduction hinges are complete junk. Put a search out for used GM hinges.
Old 06-27-2013, 04:14 PM
Sonar Chief's Avatar
I'll second that... search for GM hinges and have them rebuilt. I sent mine to Year One and they blasted, new pins and bushing ... nice work.
Old 06-27-2013, 07:19 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Camaro Specialities out of New York has used hinges.
Jeff
