Old 04-17-2006, 11:01 AM
Derek69SS's Avatar
Derek69SS Derek69SS is offline
Default LT1 swap - throttle cable?
I'm curious what others are using, or what might work for me for a throttle cable in a '69 Chevelle with a '95 LT1.
There may be a bunch of similar questions coming from me as I slowly get closer to finishing this project up.
Old 04-17-2006, 03:30 PM
Musclerodz's Avatar
Lokar would probably be your best bet.
Mike
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-17-2006, 07:30 PM
samckitt's Avatar
samckitt samckitt is offline
Originally I used a factory F body cable in an 86 Monte SS. I am going to order one from here: http://www.controlcables.com/Search....hrottle+Cables
You can order custom lengths. If you do order one, make sure you tell them you need the barrel (little cylindrical metal thingy on end of cable) to fit the LT1.
Scot
Scot
86 Monte SS
LS2/T56 Magnum
Old 04-18-2006, 03:41 AM
130fe 130fe is offline
I used the lokar one. The only thing I didn't like was the $40 cable bracket, other than that it is fine.
Chris
1968 Camaro SS
LS3/T56
Full of DSE and Holley parts
