Old 07-03-2013, 02:34 PM
hiwayman hiwayman is offline
Default 1050 braswell 3circuit
hey guys have this on a small block yip way to big had the combo on the dyno no drama but as soon as i try to idle/ cruse way to rich will kill the plugs has any blocked the intermidiate circuit
hey guys super rich at idle here are the carb spec 28high speed 51intermidiate 29idle air bleed 79primary jet 85power valve 92cscondary no pv in rear mixtuer screws 3/4 turn out primary blades set so transfer slot is square cam at .050 intake250 exuast256 valve lift in624 ex605 any starters thanks
Old 07-03-2013, 03:09 PM
Ron Sutton's Avatar
How much "steady vacuum" are you seeing at idle & cruise?
Ron Sutton Race Technology
Old 07-03-2013, 03:23 PM
Ron Sutton's Avatar
Also ...
a. Does the intermediate circuit have a removable jet type of orifice in your carb's metering body?
b. Does it seem to be a "similar amount too rich at both idle & cruise rpm" ... or is does one seem richer than the other ?
c. Are the emulsion orifices simply drilled holes ... or removable jet type orifices?
d. 3-circuit carbs are designed to be richer on the low end. So I don't normally see them in this application. Did you buy this carb for this application? Is it new or used?
e. Do you have a A/F meter you can use to help dial this carb in?
Old 07-03-2013, 04:44 PM
intocarss's Avatar
This?
http://motorsportsvillage.com/forum/...php?f=6&t=9717
http://motorsportsvillage.com/forum/...=9316&start=15
Old 07-03-2013, 04:50 PM
Ron Sutton's Avatar
I would say all the help he needs is right there.
Old 07-03-2013, 07:34 PM
intocarss's Avatar
I hope so, I did it to my drag car and it helped a lot
