Old 08-13-2013, 06:58 PM
Riddler's Avatar
Riddler Riddler is offline
Default Project EH-Body - 1976 Plymouth Duster
Well I'm new to lateral G but I've been building my car for 3-4 years. Please forgive as I try and get this new build back on track to match up with the others sites I'm on.
Here's a rendering I had done from Mascoll Designs.
The plan for the car is 6.1L Hemi (425hp), T-56 (Viper) and an 8 3/4" rear end. I have a tube front end with rack and sway bar and a rear 4 triangular four link.
The suspension is all from Reilly Motorsports.
Please forgive me while I ad 3-4 years of posts to this thread.
Riddler
Riddler's Avatar
This is what the car looks like when we brought it home...
Overall a solid car from the USA. I'll be adding to this project long as time goes on.
Riddler
Old 08-13-2013, 06:59 PM
Riddler's Avatar
First things first. The interior smelled like Moth Balls. It was used to get the mice out of the car since it was stored in a barn. The entire interior was removed.
One Seat removed
Both Seats removed
Rear Seat and Carpet Removed
The only rust I've found so far. Also note the center hump has had another hump installed over it with screws and seam sealer.
Driver's Side Rust
Well the interior is out, I've located and purchased a set of floor pans. Not sure I'll need them since it's mostly surface rust. I can prolly make due just patching with some small sheet metal cutouts for the holes.
Total dead mice found - 4
The plan is have the entire car blasted.
Riddler
Riddler's Avatar
Well I've started to disassemble the car down so that I can get it blasted.
Front end gettig stripped down first.
Fenders came off once we found all the nuts.
Only surface rust. Woohoo!
Riddler
Old 08-13-2013, 07:00 PM
Riddler's Avatar
Well the disassembly continues. This time I went to the back of the car and started to remove everything.
The gas tank was brand new. At least that's what I've been told.
This is going to be a larger job. Someone in the past has screwed down another (Volare/Aspen) center hump over the stock hump. Then they seam sealed it. Gonna have to grind the screw heads off a peel this center section off.
This concludes this disassembly installment.
Riddler
Old 08-13-2013, 07:02 PM
Riddler's Avatar
Well I got alot more done this weekend. I'm also finally up to date on the pictures. This is how the car is currently sitting...
Look ma, no glass...
Pictures of the glass out of the car.
Front:
Rear:
So this was my goal this weekend, to get the glass out. After about an hour I had it all out. So I went for bonus removal on items.
Started with the dash now since I could get to those bolts.
I figured the column would be very troublesome to get out. Nope the old owner had taken all the bolts, pins etc out and left them out. Just a quick pull and it came.
Now this this was all removed, we went to remove the brake booster and resivoir.
Not much left to remove. Engine and tranny will come out when I can get a hoist. The rear end can come out anytime now.
While taking out the rear quarter glass I found something strange. The driver's side has an extra piece of metal. How odd!
DRIVER'S:
PASSENGER'S:
This had to be a factory error. The piece of metal was not cut out unless god himself removed it. No evidence of cutting or anything.
Riddler
