Old 11-09-2013, 05:56 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Default T56 Magnum shift quality
I'm curious what kind of shift quality you all are experiencing with your T56 Magnum. I just did a 500 mile break-in oil change on my new T56 Magnum but the shift quality has been notchy since day one. It feels like syncronizers are sticking but never having driven a car with a T56 I don't know if this is normal or not. The 3rd and 4th gear shifts seem to be the worst but the problem seems to lessen as the transmission gets heat soaked. I'm wondering if I can use something different than DexIII maybe a synthetic like Transynd or maybe some kind of friction modifier additive. I would like to know what others experiences are.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 11-11-2013, 10:19 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I'm curious about this also. I have about 800 miles now on my T-56 magnum and the shift to 3rd gear is not as smooth as all the other gears. Sometimes it slides right in, sometimes it catches a little bit and doesn't want to engage as smoothly as it should. Other gear shifts are fine for me, although all of them are slightly notchy. It's not a bit deal, but something I was wondering about also and I'm glad you brought it up. Look forward to seeing what other people say. I'm using the Tremec shifter that came with it and whatever fluid they recommended on the tag that came with it. I can't remember exactly what it was. Would have to check when I get home.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 11-11-2013, 12:52 PM
DaleTx's Avatar
DaleTx DaleTx is offline
I recently installed a Tremec T56 Magnum transmission in my car and have driven about 1,500 miles on the street... and couple hundred miles on the track at HPDE events. The transmission shifts smoothly in all gears with no issues. I run Mobil 1 synthetic ATF (this is the fluid recommended by the vendor I purchased the transmission from), and the stock Tremec shifter.
The trans shifts up and down smoothly... even into the low 7K rpm range. I'm very happy with the transmission.
Just one thought.... make sure your clutch is completely disengaging, try running the pedal just a bit higher and see if it makes a difference.
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 11-11-2013, 01:03 PM
chr2002ca's Avatar
Thanks for the feedback Dale. I'm pretty sure I did not use that particular fluid in mine. I think I went with a non-synthetic by Valvoline. I'll try the Mobil 1 next time I get around to tinkering with the car and see if it helps. Not really much of an issue for me so it might not be anytime soon.
Chris Robinson
Old 11-11-2013, 01:33 PM
Dale brings up two good points. Clutch air gap can be a factor.
Old 11-11-2013, 02:03 PM
chr2002ca's Avatar
I know the gap I left between the clutch fingers and TO(when the TO is fully depressed) is dead on the money and I'm 100% confident the clutch fully engages and fully disengages. The travel necessary to disengage a DYAD clutch is shorter than most dual disc setups, and happens long before my pedal hits the bump stop(probably at 50% of pedal travel). Considering that it shifts into all gears just fine including reverse, and only 3rd is a little notchy, it just snagged my curiosity a little bit which is why I posted. It might simply have to do with how I actually move the shifter stick on my shift from 2nd to 3rd, because sometimes it goes right into 3rd perfectly like all the other gears. I think I saw a Youtube video where someone was demonstrating the proper movement and hand position on the knob for that particular shift, so it could be something as simple as that for me. Like I've mentioned, it's a slight thing that I notice randomly and isn't really a big deal for me. I have high regards for this transmission and clutch so far. Very happy with them.
Chris Robinson
Old 06-02-2015, 12:35 PM
samckitt's Avatar
samckitt samckitt is offline
So how do you gain more clearance in the clutch if its not disengaging enough?
Scot
86 Monte SS
LS2/T56 Magnum
Old 11-11-2013, 01:01 PM
Sieg's Avatar
Sieg Sieg is offline
I have about 2,500 on mine now. Running Mobil 1 atf since day one and Hurst shifter. I was concerned initially but it's improved to the point that I don't think about it, especially the 2nd to 1st downshift.
