Old 12-16-2013, 12:04 PM
OBeer-WAN-Kenobi's Avatar
Default How about some clutch recommendations?
Hi all,
I split my donor (2004 GTO) engine and transmission this weekend to have a look and I think I'd like to put a new clutch in while I've got it apart. In actuality, the clutch doesn't really have that much wear but there are hot spots and chatter on it so I think the previous owner was one of those people that shouldn't have been driving a manual. I found out no one around here faces pressure plates anymore and I can't even order just the clutch disc itself so it looks like I'll have to buy new.
Anyway, I'm looking for a good value replacement, and even a stock one might be OK for now. My eventual goal of "as close to 600 RWHP I can get" doesn't really need to factor in here as that will be a long while due to funds. I've got a lift so I'm not too worried if I need to change it out later. However, as with a lot of my build, I'm over-doing it where it makes sense financially with my end goals in mind.
I'd like to not have to mess with bell-housing extensions and other weird stuff for now but would like to get a good daily driving clutch that will hold as much torque as possible for a reasonable price.
Thanks!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 12-16-2013, 01:06 PM
NvrDun71 NvrDun71 is offline
GM LS7 clutch kit
71' Nova - LY6, T56
Old 12-16-2013, 05:43 PM
Originally Posted by NvrDun71 View Post
GM LS7 clutch kit
Doesn't that require a bell housing spacer or something? I thought I read that somewhere but maybe I'm wrong.
'69 RS Camaro
Old 12-17-2013, 09:55 AM
No special bellhousing or spacers required. They are good bang for the buck, have smooth operation, and can hold up to some power. Mine needed a small slave shim for proper engagement but was a direct bolt in otherwise.
71' Nova - LY6, T56
Old 12-17-2013, 12:07 PM
I think I may go this way then when budget allows. I like running off the shelf parts whenever possible so this is up my alley.
'69 RS Camaro
Old 12-17-2013, 06:32 PM
71RS/SS396's Avatar
600 rwhp will be right on the edge of what the LS7 clutch can handle.
