Old 02-01-2014, 06:04 PM
silvermonte silvermonte is offline
Default Cleaning tumbler
Hello, Im in the market for a tumbler to clean bolts and small items. I have about a million of the little c-clips that attach to the fender, and I would rather just have them cleaned then have to buy new. I was going to get the 5lb from harbor freight today but they didnt have any in stock so now im on the search on the internet and was wondering if you guys had any input on what works really well for dirty and rusty bolts. It gets old having to use a wire wheel to clean bolts and certain things you just cant clean with a wheel.
Old 02-01-2014, 06:30 PM
IMPALA MAN IMPALA MAN is offline
Default Bolt cleaner
This may sound too simple but it really works. I was bolting on a used Tune Port set up and needed to clean about 20 bolts and small brackets. I put them in a Gatorade bottle (it has a large cap / opening). Then I put in about a two cups of a 50/50 mix of silica sand and kerosene. Then shake it like crazy. You can play with different grits to get a desired result. I used a pretty heavy grit a little smaller than a pencil lead. Either way, it cleans them really good. No need for a wire wheel or brush. When I get the bolts out, I just put them in a second bottle with hot soap and water. Shake it like crazy, take them out and dry accordingly.
It's cheap and works great. What else can you ask for?
Old 02-01-2014, 08:07 PM
Are you talking about the sand used for sand blasting? I have some of that stuff sitting around and Ill give it a try. That would probably work better on the c-clips then a tumbler anyways, bolts on the other hand im still a skeptic, but ill give it a try anyways.
Old 02-01-2014, 09:13 PM
Sieg's Avatar
Sieg Sieg is offline
Here's another choice: http://www.midwayusa.com/find?sortby...ensionid=11893
Old 02-01-2014, 09:15 PM
Solid LT1 Solid LT1 is offline
My buddy has an automotive machine shop. One piece of equipment in there is a tumbler set up with steel shot and a compartment that has steel hoops welded to it. You put your hardware in the compartment with the steel shot latch it up turn on the timer for 20 minutes and it rotates the compartment in a bath of cleaning solvent. This is the greatest piece of fastener cleaner I have ever used. After the gunk and rust is off....I take my parts to a plating shop for zinc plating and pickling to normalize the hardware after plating. I have done some bench testing against new grade 5/8 fasteners to check for problems of hydrogen embrittlement and loss of hardening....make sure your plater knows what the heck he is doing if you have fasteners redone that way. I am going to buy or build one of those tumblers if I ever move away.......
Old 02-02-2014, 06:54 PM
Default Grit
I used a Black Beauty Sand Blast abrasive fine grit 20 40 abrasive. You can find it on ebay. It will work great on the bolts too.
Old 05-28-2014, 01:48 PM
FANTM58 FANTM58 is offline
Default tumbler
I purchased a tumbler for the brass during reloading.
did a lot of research and ended up buying a unit from
Cabelas, great price , great unit !!
Old 05-28-2014, 09:49 PM
After going through 2 tumblers for car parts I ended up buying a cement mixer from harbor Freight. Load it up with ceramic polishing media, garnet, polish soap and what ever you need cleaned up.
I use it to deburr mostly. 2 lbs at a time. Much faster han a tumbler.
http://www.fornobravo.com/forum/atta...-199-mixer.jpg
