Old 05-11-2006, 07:06 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Default Rendering
Here are a few shots of the Rendering that Kris did for me. Let me know what you guys think.
Specs:
67 Camaro
383 SB with Tunnel ram
TKO 5 speed
narrowed 12 bolt with DSE min tub (done by Vince @ Meanstreets PErformance.)
17 x 11, 17 x 8 Budnik shadow ss wheels, 245, 315 tires
DSE Front upper and lowers, spring, sway bar, QA1 shocks.
Trans Am spoiler, Le Sabre mirrors
Future plans call for converting manifold to Fuel Injection.
Mike
Old 05-11-2006, 07:38 AM
Hdesign's Avatar
Hdesign Hdesign is offline
Freakin saweeet! Nice color combo, the tomato red stripe is a little much for me though. I'd like to see it with either a silver or more subtle red stripe.
Ben
Ben Hermance
Hermance Design
My Facebook
Old 05-11-2006, 07:51 AM
TravisB TravisB is offline
Don't care much for the red stripe or the tunnel ram sticking out of the hood......hope you wanted honest opinions
Kenny Davis Hot Rods
Old 05-11-2006, 08:09 AM
68protouring454's Avatar
Default car
do you have a mullet??? lol jk, looks great but the air horns are a bit much imo
Old 05-11-2006, 08:35 AM
Radlark's Avatar
Radlark Radlark is offline
Just being honest........What is different about this camaro than the other ones he has rendered besides color and wheels
still looks good!
Old 05-13-2006, 06:59 AM
ryoung3 ryoung3 is offline
still looks good!
IMO it seems that what Radlark is trying to say is that it looks like every Camaro that has been rendered looks to use the same, if not a similar model, and just has color changes and different wheels. It's nice, but how many times can you re use the same car?
Old 05-11-2006, 08:38 AM
Kustomchopshop Kustomchopshop is offline
With a hinged hood the opening in front of the stacks for the tunnel ram would probally have to be opened up alot to clear that lip on the swing and might lend a little to the unattractive side with the big gap. a lift off would work but a sure PITA
Matt Inscho
Kustom Chop Shop
Decatur, AL
256-227-5670
Old 05-11-2006, 09:37 AM
Kris Horton's Avatar
Kris Horton Kris Horton is offline
Ben
The bright red stripe was kind of a necessary evil. Mike had already painted the engine compartment a bright shade of red, but decided to go with a darker shade on the exterior. We used the pinstripe to tie in the engine compartment color.
Radlark,
I guess that's a problem you run into when so many people are building Camaros. You can only do a Camaro so many ways without getting into some serious spending.
Kris
Old 05-11-2006, 10:08 AM
Kris
I'm no designer but I probably would have just done red guts and maybe everyones favorite....red brake calipers to tie in the engine compartment color or repsray the engine compartment the color I wanted it!
Old 05-11-2006, 11:43 AM
mdprovee's Avatar
Thanks for the honest opinions..it is not everyones cup of tea.
I painted the engine the red color, and it is assembled with all the accesories, and has been run. Didnt want to take it all apart to repaint. Trying tie it together.
I cut a small hole in the hood, just big enough for the stacks. I will have to remove the stacks to open the hood. That way I can keep the hole small.
Mike
