Old 02-19-2014, 11:42 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Default Power steering flow control valve install question
Hi guys
I received the Billet Specialities 2 GPM flow control valve , and yesterday spent a couples of hours trying to install the fitting. I started to untighten the high pressure Power steering line fitting and noticed it was a male flaring fitting that is connected to the GM control valve,which is different than the Billet Specialities that has the threaded male connection.
Does this mean that I need to change the male flaring fitting on the presssure line or the BS valve I ordered was not the right valve for the application since it has a different arrangement than the existing one I have?
I am totally confused and appreciate your input guys.
72 Camaro RS:SOLD
68 Camaro:
Old 02-19-2014, 02:31 PM
72Z/28's Avatar
I guess I ordered the wrong flow control valve. I should have ordered the Detroit Speed flow control valve instead of the Billet Specialities one
72 Camaro RS:SOLD
68 Camaro:
Old 02-19-2014, 06:39 PM
David Pozzi's Avatar
Most of the aftermarket outlet fittings like what you bought are -6 AN fittings. Hydraulic shops call them JIC fittings. The flare angle is 37 degrees. Normal automotive fittings are 45 degrees.
The DSE fitting is likely to be a -6 AN, same as what you have.
What pump are you using? Is this for a Mustang Rack?
http://www.PozziRacing.com
Old 02-19-2014, 06:46 PM
72Z/28's Avatar
Originally Posted by David Pozzi View Post
Most of the aftermarket outlet fittings are -6 AN fittings. Hydraulic shops call them JIC fittings. The flare angle is 37 degrees. Normal automotive fittings are 45 degrees.
I believe it is an LS6 power steering pump that came with the crate engine.
Well I placed an order for the DSE flow control valve directly through them.
72 Camaro RS:SOLD
68 Camaro:
Old 02-19-2014, 09:06 PM
Then you also need to reduce pump pressure to 1000 psi max. The fitting just reduces flow.
Old 02-21-2014, 07:13 AM
72Z/28's Avatar
Is there a part I need also to change in order to reduce the pressure,if so what do I need to change and where to get it from?
72 Camaro RS:SOLD
68 Camaro:
Old 02-21-2014, 07:15 AM
72Z/28's Avatar
If have heard FBody power steering pump pressure is around 1200PSI
72 Camaro RS:SOLD
68 Camaro:
