Old 02-25-2014, 11:57 AM
69*Goat's Avatar
69*Goat 69*Goat is offline
Default Need help with trans swap info please.
I am starting the search for a 6-speed manual so I can make the change from automatic to manual in my 69' GTO. At this point, I am not wanting to buy a "Brand New" kit, because I bet, I could get a good used trans, and then cobble the rest of the parts up separately. I am running a Pontiac engine (No LS here). Have any of you guys made this conversion? If you have, which year 6-speed did you use, and what do I need to shy away from?
Please let me know.
Thanks in advance.
Old 02-25-2014, 03:26 PM
hifi875's Avatar
hifi875 hifi875 is offline
go to ls1tech.com and find a lt based t56. It may or may not work now that I think about it. they are less priced than a ls based, but you may need a bop adaptor. there are a lot more smarter people than me on here so im sure they will chime in.
Old 02-26-2014, 12:48 PM
69*Goat's Avatar
28 views, and no one else has any ideas? Come on guys....
Old 02-27-2014, 07:16 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
We just put a Magnum trans in a (70 I believe) Cutlass (with olds engine).
Used a McLeod BOP modular bellhousing (I think Quicktime makes one too).
I believe a regular 98-02 LS1 T56 would bolt up the same but then you have the added cost of modifying it for a mechanical speedo drive if you aren't using an electronic speedometer.
On the olds we had to have a custom pilot bushing made because the auto crankshafts are different than the manuals. Not sure if Pontiac is similar in this regard.
You will need to modify/rebuild your trans tunnel as well.
Old 03-01-2014, 02:39 PM
69*Goat's Avatar
Thanks, I'm not worried about the speedo, because I am running a Speed-Hut GPS speedo. I am running a stroked kit in my engine, so I bet the crank will go either way. I can get a bearing, I'm not worried about that.
Old 03-21-2014, 04:08 PM
71 RAT's Avatar
71 RAT 71 RAT is offline
Just putting in a 2nd note about trans tunnel modifications. GM A Bodies have a small tunnel area. T56 is huge and doesn't taper down behind the bellhousing. The lower your car is, more surgery required. I'd love to do a t56 swap, I can't cut up my OE floors on my Chevelle. Yet!
Nice looking GTO and poncho powered. I'm huge A body fan!
71 SS 454 TH400 2.74 1st gear GV Overdrive 3.55 Gear SC&C Stage 11 QA1's 4 Wheel Baer Brakes AGR Box Straub SR .630 .612 lift 240 256 [email protected]
83 K20 454 TH475 NP 205 Dana 60 Track Lok Detroit Locker Rear
58 Ford 821 Powermaster Loader Backhoe Restored Family Heirloom
