Old 03-16-2014, 03:57 PM
V8TV's Avatar
V8TV V8TV is offline
Default Painless Performance 60509 LS1 LS6 extended length harness and GM ECM
Item Location (City/State):Red Bud, Il
Price:$850.00 shipped
Description:
Painless Performance 60509 LS1 LS6 extended length harness and GM ECM, used for mock-up
PN 60509
Year: 1997 - 2004
Make: General Motors
Model: Camaro, Firebird, Corvette
Engine: 5.7L LS1 / LS6 w/ Cable Throttle Body
Trans.: 4L60E, T-56
For installations of a mechanical throttle body LS1 / LS6 engine with a 4L60E or T-56 transmission using ECMs with service #12200411 or #9354896. These engines and transmissions were factory equipped in 1999 - 2002 Chevrolet Camaro. This harness may also be used when a throttle by wire LS1 or LS6 from a Corvette is converted to mechanical throttle. Harness includes all connections for fuel injection operation: ECM, TPS, IAC, CTS, IAT, MAF, MAP, Injectors, Coils, CMP, CKP, Knock, VSS, Transmission, Front Bank 1 & 2 O2 Sensors. Harness does not include any emissions related connections. Harness incorporates its own 8 circuit fuseblock with ignition relays and connection to factory style fuel pump relay.
This extra length harness allows eight feet from the back of the intake manifold to where the fuseblock and ECM mount. Perfect for those that plan to mount these components under or behind the passenger seat.
This kit includes:
All new fuel injection harness with OEM fitment connectors and harness breakouts
OBDII connector, mounting bracket and check engine light
Crimp-on terminals, rubber grommet
Mounting hardware
Installation manual
Pm or email, call 314.783.8325
Thanks!
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
