05-22-2014, 06:46 PM
Scott Mock VRP subframe
First let me state that this thread is being made to state facts and not to bash anyone. This is based on my personal experience and everyone as adults should make there own finally decisions on were to spend there money and who to deal with. I have all emails to verify my posts and since contacting him he had changed his listing in the suspension section and deleted all pics of the new 2013 Scott Mock VRP frame design.That being said on I go.
I talked to Scott Mock in mid December 2013 and purchased his new 2013 VRP frame design because he was running a $500 off for members,$5400 total. We discussed what I wanted done and a completion date of the end of January 2014.
After 3 months of his excuses, building me the wrong frame, snow, crack ribs, car show with his son and building me the wrong subframe and having to re build the right subframe for me, I finally received my subframe for my 68 Camaro.
On inspection i found cold/ bad welds, missing upper shock mount "diamond" supports, the cross member only had one mounting location for T56 transmission even tho his new design showed multiple transmission mounting locations,the frame was not Da'd or sanded ready for powder coating as his add stated and the most recent was the sway bar mounting tube not square.
I contact Scott and he refund me $200 for not welding on the "diamond" upper shock support brackets, to grind out his bad welds and re weld myself and to sand the frame myself to get it ready to powder coat. I took the refund because something is better then nothing and he apologized. Recently when I went to install the sway bar it was difficult. I put the frame against the wall and checked for square and measured it and found the sway bar mount was way off.
I again contact Scott and he told me
" i already refunded you $200, discounted the frame $500 ( even tho it was a discount for all members), the sway bar mount being off is an easy fix, just cut off one side , square it up and re weld it"
He then went on to tell me I could fix it myself easy or send it back on my dime and he'll fix another of his mistakes.
This was the last draw for me. I told him I'd keep the frame and repair it myself and I'd never do business with him again. I told him he should of done quality work to begin with and not count on the customer to do the repairs. If i didn't know how to weld I'd be paying more then his $200 refund to repair this frame at a shop. After a 3 month wait this frame should of been top notch.
To me customer service is everything and wrongs need to be corrected, no excuses. He did own up to his first mistakes and refunded me $200 but didn't correct the sway bar mistake. It was to many mistakes to begin with. I work graveyard shift and don't have time to return frames on my dime and wait for his mistake to be fixed for the 5th time after I already paid $5400 dollars.
Now I have to, bend and weld on the upper shock "diamond" supports, grind out and re weld bad welds,DA my own frame, cut off the transmission mounts and fabricate and weld on my own and now repair the crooked sway bar mount. All his mistakes.
He lost my business but most of all my respect.
I have all emails, pictures of his original posts, etc to verify everything. Members are also welcome to come view the frame before i repair it myself.
Hope this helps members when making there next expensive purchase.
Below is a few pics of bad welds, crooked say bar mount, etc. Thanks Everyone
Reason: corrected spelling, corrected dates
05-22-2014, 09:35 PM
Ahmad,Since you did not use the $200.00 I sent you to fix my short coming's,Please use that money the ship the frame back to me.I will fix it ASAP and ship it back to on my dime.You didn't wait 6 months to get the frame.My Old dominion bill of landing is dated 3/28/2014.So my math says its 3 months 15 days from your 1st payment and about 2weeks after your 2nd payment.Thank you Scott.
Reason: spelling
05-22-2014, 11:45 PM
Hi Scott, you are correct it was 3 months and some days. I just checked emails and verified your are correct. But it was still 3 months after the promise date.
As for sending back the frame, I'll just repair it myself at this point. I honestly feel uncomfortable at this point returning it. If something happens between me shipping it and you receiving it or vice versa I'm out $5400.
If anything you can send me properly bent "diamond" upper control arm supports and properly bent/ drilled or slotted transmission crossmember brackets, slotted preferred. This will at least save me a few hours fabbing up my own.
I feel I should of been compensated accordingly at thus point for all the work required to get this frame were it needs to be and should of been to start.To repair this frame is a minimum 16 hours shop rate I should of been refunded for having to, grind out bad welds, welding, cutting off brackets,fabbing new brackets,etc. And that's a low estimate of time being generous on my part.
That would of fixed the problem.
05-23-2014, 07:16 AM
Ahmad,I could fix your issue's( I'm sorry you are having them,clearly I dropped the ball) w/the frame in 2-3hour's max(16 hour's labor!!!! somebody's on crack).Here are your choice's.Option A-Keep the $200.00 and fix it your self,Option B ship it back to me & I will fix them and do it to your satisfaction and send it back to you on my dime ASAP( I shipped the complete frame w/all componets to you for $198.32,so I know the frame can come back for the $200.00 I sent you),Option C-I will make you some diamond gussetts and trans tabs with slotted holes as per your drawing's so I know what you want.This my final reply on this thread.Thanks Scott.
05-23-2014, 08:30 AM
Hey Scott, thank you for public admitting your faults. This thread once again was not intended to bash you. But when welds are questionable/structure and my safety and my family, friends are in order now that's important.
I don't build frames or know suspension geometry by any means, but I do mig, tig and arc weld daily. To back grind out most of the bad welds,re weld them,cut off and make new transmission mounting bracket for multiple transmission options, cut off sway bar mount and re weld, bend diamond brackets and re weld, DA sand the entire frame in 3 hours is far from the truth. If you can accomplish this all in 3 hours that's amazing and my hats off to you,but the quality and details don't show in this frame you sent me. But it'll take me 16 hours to do it properly, safely with quality welds etc.
As far as a resolution,I think you should build me a properly quality welded frame as you originally posted in your new frame design before you deleted the pictures, with the small details I originally requested and take back this frame and do as you please. This without a question should be an easy task to agree to. Once I would receive and inspect the new frame I'd send this frame back. To me that's what should be done and should of been done from the start after the sway bar issue. I should of even gotten some upgraded mandrel bent frame rails for the wait and inconvenience.
If not,as stated before, I'll fix this one and let this be a learning experience of what vendors to deal with for everyone on this site when safety, quality, customer service and time are important. Anyone who has purchased a VRP subframe I urge you to check it for any defects, welds, etc. This is your money and most importantly your life and others safety at hand. Don't be afraid to speak up when things aren't done as promised or as expected. I was contact privately by a member who had the same issue with his VRP subframe but is scared to speak up. I hope he changes his mind. Thanks everyone for taking the time to read this. I hope this helps when making your next purchase.
Reason: additional information
05-26-2014, 03:36 PM
Since I stand behind my work,here's what I am willing to do.Ahmad you take the sub frame back to business address I shipped it too(strapped on the pallet please).I will call Old Dominion freight co. And have them pick it up and deliver to me,I will fix it or replace it at my choice.And return a properly built frame to you ASAP.And you can keep The $200.00 dollar's for your time.Thanks Scott.
