Old 02-24-2005, 11:48 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Default Backup light wiring
Ok, I'm putting in a new wiring harness and new TKO600, and have the following question. There are 2 pigtails for the backup light on the trans. I don't see any backup wires in the engine side of the harness, but there are 2 under the dash. Do I route those back through the firewall and down to the trans wires?
As a follow up, where do the two wires under the dash go that are marked 'ignition switch to neutral safety switch' and 'neutral safety switch to starter solenoid'? These are two wires (thicker, maybe 12 guage) that are bare and not part of any connector.
Thanks,
-Tom
camarorestoration.com
Old 02-25-2005, 05:43 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Painless Harness???
In most cases you have a 12+ hot ignition on wire that routes through for the back up lights. The two wire switch on the trans allows the 12+ wire in and then out to the lights. The lights are grounded near the rear body panel. It appears you will just loop through on your two wires under the dash. You will want to power it up and verify that you have a 12+ ign on on one those two and the other goes to the back up lights in the harness.
The thick wire is your neutral saftey switch. It interrupts the 12+ ignition START power to the starter unless the car is in park/neutral...or the clutch is in.
If you wish to make it functional you will need to get a neutral saftey switch for your clutch pedal. Or, if you want to live on the wild side you can wire it direct, but the car will be able to start in gear that way.
Or...you can run it through a hidden switch for anti-theft override.
Hope that helps!
BTW-the saftey switch wire is usually purple, and back up light power is usually green.
Old 02-25-2005, 10:58 AM
rockdogz's Avatar
Thanks for the help - yep Painless harness. I'll try to verify on the green wires for the backup lights, but I would hope that I can simply take the two wires that end up under the dash and re-route them down to the trans wires. I shouldn't have to mess with the backup light wires that go out to the rear of the car to the actual lights, right?
I'm a little confused on the neutral safety switch - do you know which part I would use for a manual trans? Is it just a switch that detects when the clutch pedal is depressed so that the car will only start when it is? I searched for neutral safety on Classic Industries' web store and got part E237 - is that it? Or is that for an automatic?
Thanks,
-Tom
Old 02-25-2005, 11:16 AM
69MyWay's Avatar
I don't know what you are using for a clutch pedal. The older neutral saftey switches were wired through the clutch pedal. The switch would mount to the clutch pedal bracket and close when the clutch was depressed. Here is an example of one for a 1979 Chevy truck. If you got one like the one pictured below, you would only make up a simple bracket to hold it in place. On the cars with auto trans the neutral switch and back up switch are made together in a cluster that usually mounts on the column for column shift cars, or in the center console.
That E237 is for auto trans.
These kind screw into the trans:
Old 02-25-2005, 11:37 AM
69MyWay's Avatar
They don't show a picture of it here, but the 1969-1971 Vette manual neutral switch is pretty cool. These mount on the pedal housing and you attach a wire arm to the pedal to trip it when depressed:
EH4-064 1969-E77 NEUTRAL SAFETY SWITCH ETENSION MANUAL TRANSMISSION
as available at www.madvet.com
Old 02-25-2005, 11:57 AM
rockdogz's Avatar
Thanks again - I'm using the stock mechanical setup from Rick's. Wasn't there a stock neutral safety switch for the factory 4 speeds of the day? I would think someone would have a reproduction of that which should fit into my setup without any modification
-Tom
