Old 07-06-2014, 12:16 PM
Track Junky's Avatar
Default Baffled
I ran my car at Sonoma and everything was fine. Did a rear gear swap but didn't drive the car till I installed new brake pads.
Problem......car is hesitating under load. I can goose the throttle with car in neutral with no issues but when I drive it and open the secondary's up the car is hesitating under load with slight pops out the exhaust.
So far I have torn the carburetor apart twice, replaced power valve and accelerator pump diaphragm, checked float level, checked and tightened my fuel lines, replaced plug wires, replaced dizzy cap(had a crack in it), and checked a few of the plugs to see if they were fouled.
Not sure if its a lean miss or electronic.
Any other suggestions?
Gaetano Cosentino
Old 07-06-2014, 01:17 PM
JB400's Avatar
JB400 JB400 is offline
Is your fuel pump putting out enough gph?
Old 07-06-2014, 01:26 PM
It has in the past and has been on the car for 4 years now with no changes to engine. It could be on its way out though.....
Odd thing is that car was running fine at the track a few weeks ago. It sat in the trailer for a few hot days afterwards and then I took it to get a gear swap. Just seems odd that it would do this after running fine at the track.
Just did a coil swap so I can rule that out.
Gaetano Cosentino
Old 07-06-2014, 01:49 PM
Pull all your plugs and report color or condition.
Old 07-06-2014, 02:21 PM
1,3,5, & 7 look the same. dry and medium charcoal colored. taking five....its gotta be over 100 in my garage
Gaetano Cosentino
Old 07-06-2014, 02:30 PM
Jay Hilliard's Avatar
After checking plugs, check distributor, then check plug wires and measure resistance/ohms with meter. Wires should measure very low resistance. Under load a wire that has high resistance will cause similar issue.
Jay
Old 07-06-2014, 02:31 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
You mentioned a gear swap, what did you go from, and to?
