Old 05-30-2006, 06:15 AM
syborg tt's Avatar
Default Wastegate Dump
Okay need a little advise.
Some people say it's okay to have the wastergate tube dump in like the picture below. Other say that it is better to go in at an angle to decrease
See quote below
These guys probably know a lot more than me, and not trying to be nit picky, but in all my reading in turbo theory books they stress that, if possible, the wastegate exhaust tubes be angled to go with the flow in the main pipe not across it, to benefit from the low pressure area created by doing this.
here is a picture of another engine with similar entry
marty-mj
Old 05-30-2006, 06:22 AM
J2SpeedandCustom J2SpeedandCustom is offline
Looks good to me Marty.
You didn't want to run open wg? Man I love the sound of open wg's!!!
Jeff Allen
J2 Speed and Custom
Old 05-30-2006, 08:51 PM
boonedog boonedog is offline
See quote below
marty i would as the guys over in ls1tech they now there stuff when it comes to forced induction or you could ask jose at forced inductions.com he is a real cool guy and nows his sh$t.
good luck and things with the pickup are coming along nicely
Old 05-31-2006, 06:14 AM
JamesJ JamesJ is offline
The motor on the bottom was built by Nelson Racing engines, if that is really that "bad" of a thing to do I dont think that they would have done it. It is probably one of those things that if you have it at an angle it makes more sense but the difference would be very small and unless you are needing every single HP then it may be done so it looks better.
James J.
Old 05-31-2006, 03:04 PM
orange88 orange88 is offline
it should work ok but i read some where thats it better to dump it in at least 12 inches away from the turbo. i guess it makes it work better
Old 05-31-2006, 11:56 PM
chuntington chuntington is offline
i know its not that relivent, but all cars for the factory that come with turbos use internally gated setup! these are 'dumping' at the trubo. with this in mind i really dont feel that you going to be loosing much!
but obviously try and make the run as smooth as possiable
thanks Chris
Old 06-13-2006, 11:28 AM
enzo enzo is offline
if you have a twin turbo anything - what really matters - it's probably going to be dangerously powerful anyway.
--Enzo
1967 Chevelle SS
http://namtramedia.com/enzo/67chevelle/
