Closed Thread
Old 07-22-2014, 10:31 PM
tombar67 tombar67 is offline
Default 1st gen Camaro Schwartz Chassis - Pro-Touring - Full Frame
SOLD SOLD SOLD
Item Location (City/State):San Francisco / CA
Price:SOLD
Description:I have up for sale a Schwartz Extreme Chassis for a first generation Camaro. This is a full Pro-Touring frame that replaces the factory sub frame. Everything pictured is included. Everything is new in unused condition. Below is the spec list.
- A fully welded chassis, built on a precision jig
- Adjustable transmission crossmember
- Race-bred front and rear suspension components control arms, ball joints, tie rods, power rack & pinion, aluminum front wheel hubs with bearings, and teflon-lined heim joints for a quieter & bind-free suspension
- 14" front rotors with Wilwood 6 piston calipers
- 13" rear rotors with Wilwood 4 piston calipers
- QA1 Coilovers
- Kinesis Wheels the rears are 18x14.5 with 8.5 back spacing with 345/30/19 Michelin pilot sport radial x's. The fronts are 18x10 with 275/35/18 Michelin pilot sport radial x's.
- Stainless brake lines already bent to frame (rears not pictured)
- Sweet Manufacturing power steering rack with integral servo with braided lines
- Splined front and rear sway bar shafts
- Front end was widened 1" on each side from stock strong arm lower control arms tubular upper control arms with threaded ball joints
- Rear end is a moser ford 9" with circle track style hubs with back brace has nodular case with 3:55 posi and moser axles and has been narrowed 1" from stock
- Triangulated 4-link rear suspension with QA1 polished heims
- Chassis was modified to work with air ride or QA1 coilovers
- Chassis motor mounts are set up for LS style engine.
- There were some modifications done to the front end to increase the turning radius. Also some changes were done to the rear 4-link and front suspension to be able to adjust to a lower ride height if need be.
Old 07-23-2014, 08:52 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Sweet deal with the wheels and brakes included. GLWS!!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-25-2014, 06:15 PM
jeremy30thz's Avatar
jeremy30thz jeremy30thz is offline
Wow super nice setup glws
Old 08-03-2014, 05:44 PM
Thanks for the kind words guys.
Old 08-07-2014, 01:26 PM
8mywal8 8mywal8 is offline
Just curious dose the Camaro body bolt right to this besides cutting the rear wheel tubs?
Old 08-10-2014, 11:36 PM
Yes it does.
Closed Thread
