Old 08-06-2014, 03:09 PM
Default AL or SS or ? fuel line considerations
I'm going to work on redoing the fuel lines on the TA in order to run more hard line and reroute the lines. I have access to a hydraulic flaring tool so flaring the SS is no problem for me. I also intend to run gravel guard over the lines like factory did. I'm going for practicality instead of custom really. I'd stay with plain steel but don't want the corrosion. Unless, of course, there's something new out there that makes this no longer and issue? Otherwise, that leaves me with Al or SS. Usually, I just say go aluminum due to the issues of flaring SS by hand and the ease of working with AL. Since I have access to a hydraulic flaring tool, should I go SS? Are there other considerations I need to take in before deciding? Are there any corrosion or wear issues I should know about before putting SS gravel guard over an AL line? That's the design I was thinking about going with.
Old 08-06-2014, 03:36 PM
66fury's Avatar
66fury 66fury is offline
i think there are pros and cons of both.having a hyd flaring tool is a pro toward stainless.i went with alum due to the ease of shaping and flaring but i know its vulnerable to breakage vs stainless but its not a track car or daily driver so i went with it.
mark
Old 08-06-2014, 10:22 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
I used copper nickel lines. Very easy to bend and flare. Just practice a few times with pressure on the hydraulic flaring tool. With a hydraulic flaring tool I was able to do the Quick Disconnect ends for the fuel filter. Do a search in the wheels, tires, brakes section for copper nickel.
Guy
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 08-07-2014, 09:43 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
This is some good info guys. Thanks!
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 08-07-2014, 03:33 PM
66fury's Avatar
try not to faint at the cost of coppernickel lines.1/2" fuel line is like 10$+ a ft.i think you can buy it from fedhill.com
mark
Old 08-07-2014, 03:52 PM
Hmmmm, I've used copper/nickel on brake lines before and liked it. I may have to check it out for fuel lines too.
I appreciate the feedback.
