Old 08-12-2014, 09:16 AM
Jr's Avatar
Jr Jr is offline
Default Beefing up the rear frame 1st Gen Camaro
Hello all,
Instead of replacing the rear frame rails, I'm looking for ideas on how to beef up the rear rails. From what I've read, the rear rails aren't the strongest metal on the car. Any help would be appreciated.
Old 08-12-2014, 10:22 AM
what are your plans for the car and how bad are they now? rusty, dented?
Old 08-12-2014, 10:51 AM
Jr's Avatar
Jr Jr is offline
Plans are to run usca events and local tracks. There are no dents/ rust. I started with a good California car.
Old 08-12-2014, 11:14 AM
Ron in SoCal's Avatar
My humble opinion, the best way to beef up the rear frame rails are to replace them with solid 2x3 units. Lots out there to choose from, and one of the more established companies is Autoweld (scroll down):
http://autoweldchassis.com/spec.ivnu
In the absence of that, if you're mini-tubbing you can put 1/8" steel reinforcements or box the internal structure of the rails. Then there's the Mark Stielow way which can be found in his recent build thread post #70.
I'm not sure what the answer is (i.e. do it or don't), but if you're in the media blast stage and want to reinforce them now would be the time.
Ron in SoCal
69 Camaro in progress
Old 08-12-2014, 11:18 AM
recommended.
if you are going to weld in a rear suspension you can just tie into a cage and subframe connectors. most aftermarket suspensions are supported by a cross support or box so the actual full length frame rails are there for the ride. I'd re-weld most of the factory spot welds.
Old 08-12-2014, 12:41 PM
Jr's Avatar
Jr Jr is offline
recommended.
Agreed.
Old 08-12-2014, 12:40 PM
Jr's Avatar
Jr Jr is offline
Thank for the link. I will also look at Stielows thread
