Old 03-23-2015, 04:37 PM
samckitt's Avatar
samckitt samckitt is offline
Default Looking for a steam vent tube....
I would like to find one that connects all 4 spots into one, but I think it is like a unicorn.
Or, looking for one for the front two ports, that the hose connects straight up on the driver's side.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-23-2015, 04:45 PM
Ron in SoCal's Avatar
Maybe not exactly what you're looking for Scot, but C&R makes a nice unit.
http://www.crracing.com/ls-steam-ven...steam-vent-kit
http://www.summitracing.com/parts/cir-78-10000
Ron in SoCal
69 Camaro in progress
Old 03-23-2015, 04:56 PM
samckitt's Avatar
I had seen that Ron. But I'm not spending that much on it. But Thanks.
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-23-2015, 07:02 PM
novahollic's Avatar
novahollic novahollic is offline
Older LS1 engines have them, but depending on what intake manifold you are running, it may not clear. I know the LS6 intake has a hard time.
Old 03-23-2015, 08:15 PM
Vega$69's Avatar
Vega$69 Vega$69 is offline
You don't need the rear steam lines. How about just using the OEM set up.
Works great and not expensive.
Old 03-29-2015, 09:39 AM
jwcarguy jwcarguy is offline
Banned
Originally Posted by Vega$69 View Post
You don't nead the read steam lines. How about just using the OEM set up.
X2
GM deleted the rear stem vents for a reason
They only used the 4 port design in early Gen III engines, then deleted/ blocked off rears due to air/ steam pockets going to highest point and purge out front ports
