Old 04-05-2015, 02:19 PM
Brewtal66 Brewtal66 is offline
Default Tons of vibration in steering wheel?
Hey gang,
So this is a little off the topic of Lateral-G, but I've been fixing up a 1991 Fleetwood Pace Arrow motorhome. It's a Chevy P-30 chassis.
Recently, I started going for test drives, in it, and there is a TON of vibration and feedback in the steering wheel. On this rig, there is the frame, then a large stamped steel structure that comes up that holds the steering wheel, brake pedal assembly and gas pedal. Then they build the motorhome around that.
I've visually inspected just about everything I could, and didn't see anything wrong. There was one support brace broke, but I welded it up and it didn't do anything. I've looked under the hood, under the dash, and under the rig itself and don't see anything majorly wrong.
When driving down the road, the steering wheel is smooth, it's only when you hit a bump/crack does it get that vibration in the wheel. How I explain it is like a stiff metal pole in the ground, and you pull the top and let it go, it just vibrates back and forth like crazy. I even had the steering column rebuilt(for a different issue).
Lastly, I replaced the steering stabilizer with a good Monroe brand stabilizer, and this even has the "Safe T Plus" stabilizer attached to the steering as well.
I'm now starting to think it's something in the suspension/steering itself, but I'm not sure what it would be. Sorry for the long-winded explanation, just tried to do my homework first.
Thanks for any suggestions!
Editor, Lateral-G
[email protected]
Old 04-05-2015, 02:29 PM
With the vehicle in a safe position have someone slightly turn the wheel left and right. There is a slack point right before you feel resistance. Try to have the wheel person stay with in that point maybe a bit over.
Crawl under and visually inspect the linkage. I bet you have something worn or getting loose. Look for up and down play as well as no movement while the box is turning.
Also pull your front wheels and have them balanced and check for bends in the wheel or tread separation. For sits and giggles.
I know it's a truck but Look up jeep death wobble for other tests you can try.
Old 04-05-2015, 02:30 PM
Where was this support brace?
Old 04-06-2015, 08:21 AM
I'll do that this week and see what I can find. I'm thinking something is worn out too...nothing has been replaced under there, but I'm not sure on the mileage since the odometer doesn't work, but I know it has probably 60K or so on it. I replaced the front shocks, which were still the originals...and they were blown out badly haha.
It's under the hood, but it was just part of the tubing that holds the entire front end together, the motorhome part, not the chassis part.
Editor, Lateral-G
[email protected]
Old 04-06-2015, 11:07 AM
BMR Sales's Avatar
How are the tires? Motorhome Tires will gain flatspots as they sit so much
Shmoov69's Avatar
Shmoov69 Shmoov69 is offline
is the vibration the "death wobble" or more like a tire out of balance? My 06 F250 had a horrible death wobble on the highway that moved the steering wheel back and forth insanely fast about 30* or so if you were pulling a trailer. I ended up putting a bigger stabilizer shock on it and it "masked" it enough to be safe again. It would only do it if there was an empty trailer on the back. Only thing I could think of is that it put "just enough" weight to make the front at the right point to show the design flaw.
Maybe even unhook the stabilizer to see if it makes it worse?
Jimmy
69 Camaro - Twin Turbo'd
58 Nomad -348 Baby Rat
www.fquick.com/shmoov69
Old 04-06-2015, 01:39 PM
JpRngr JpRngr is offline
Jack up one front wheel at a time and shake the wheel back and forth at 3 and 9 o'clock and at 12 and 6 o'clock. Look and feel for excess play in your steering and suspension. Sometimes you even have to put a long pry bar under the tire and lift up and down to check for play in the ball joints.
Corey
