Old 05-22-2015, 12:14 PM
MattG's Avatar
MattG MattG is offline
Default Spanky's Rod Shop LS3 Cruise Control
I just installed this and it works perfect. This completes the "Touring" part of my ride and I couldn't be happier!!
Six wire hook up with the E38 computer:
12 volt switched
ground
hot side brakes
cold side brakes
VSS signal to speedo
ground switch from clutch
Also you have to run 4 wires through your column if you want to run the controls from your turn signal like mine.
Contact Adam Gunn at 479-216-2321 and he can set you up with this.
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 05-25-2015, 02:09 AM
Gambit's Avatar
Gambit Gambit is offline
Very cool mate. Dunno how the laws over there are but the cruise in mine will come in handy when it's on the road here in oz.
69 Camaro, LS1, T56, HTV2300, Brembos, Forgeline
As close to finished as it’ll ever be..
Old 05-30-2015, 06:20 PM
Solid LT1 Solid LT1 is offline
Smile
100KPH national speed limit? Why even have a LS Pro Touring ride over there? My buddy in Highett makes due with his 245HP L-82 Vette
