Old 10-24-2015, 08:46 PM
70PTRS 70PTRS is offline
Default Rear gear ratio
I'm going to be running a 25.9 tire (Rival 335/30/18) and a T56 magnum with a 2.97 1st gear and .5 6th behind a 450 rwhp LS1. What's the optimum rear gear ratio for my set up?
1970 RS Camaro '02 LS1, T56 Magnum in process
Old 10-26-2015, 09:17 AM
What type of driving? All around, autox, competitive autox, road coarse, etc?
Old 10-26-2015, 10:01 AM
Mostly all around with an occasional autox and a few trips to the drag strip every year.
Old 10-26-2015, 10:34 AM
Sieg's Avatar
Sieg Sieg is offline
It's a loaded question!
Here's the best tool I found to help me make the decision: http://www.tremec.com/calculadora.php
Do you already have the transmission?
Old 10-26-2015, 08:35 PM
Yes I already have the trans.
I'm thinking a 3.70 or 4.11? With a 3.70 at 1800rpms I'm cruising at around 75 in 6th;
With a 4:11 at 2000 rpms I'm cruising 75.
3:70 at 6500 in 4th gear Im going 135, 4:11 is 121 which is around what the car should trap in the 1320.
Old 10-27-2015, 05:26 AM
I was going to suggest a 3.73 or 3.90 ratio for an all around car. I think any gear in the 3.70 to 4.10 range will work well for you honestly.
