Old 12-01-2015, 10:03 PM
1965_SS's Avatar
1965_SS 1965_SS is offline
Default LS3 Engine Decision----which one?
I've got a 1965 Chevelle SS that I'm going to put an LS3 into. Car will be 85% street, 15% track time. It will have a T-56 Magnum. I will be rewiring the car with American Auto Wire, using Dakota Digital Gauges, Vintage Air setup, and a Vaporworx tank.
I'm looking at GM crate engines:
1. LS3 430HP for about $5900
2. LS3 480HP for about $6300
3. LS3 525HP for about $7300
Is it better to buy the higher HP engines and be done with it or buy the 430HP and do my own cam/spring swap on it? There is about a $1400 difference there.
If I did my own cam swap on the lower HP engine what is a good cam that would actually be better that the 525HP for $1400 or less. I've also read that there is a lower limit on cam lift/duration on these engines due to the pistons not having reliefs cut into them.
Are the GM controller kits any good or is it better to go with Speartech or something like that? The GM kits are about $1200.
Thanks for the help!
_________
1965 Chevelle SS
Project Build
Old 12-02-2015, 04:26 AM
Z06vette's Avatar
Z06vette Z06vette is offline
Hey Todd. I believe the best bang for the buck is buying the 430 engine, selecting a cam package that meets your needs (check out texas speed), using a custom built harness, and having the car tuned locally. However, that takes more time- changing the cam(but it will outperform the 525), waiting on the harness to be built (but it can be tailored to your needs), and finding a good local tuner(may have to travel, and key word is good). You'll also need a DBW pedal ,and ECM. On the flip side, you can buy everything you need, ready to go, plug it in, and go.. in half the time with the GM package. It will cost more and leave a little power on the table, while paying more $. I just went thru all this. I was so close to buying the 525, then I found a very low mileage pullout and just went with it. If you dont mind doing the legwork and already have a good tuner that is local, thats the route I would go. Either way I dont think you will be disappointed. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 12-02-2015, 09:36 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I've done an LS7 with PSI harness and 2 GM crates a 480 in my buddy's car and my 525. Both with the GM harness. The harnesses are plug and play and included the pedal and sensors.
You can not get a custom harness, ECM, pedal sensors and Dyno tune for less then about 15-1600.
It's hard the beat the GM hot cams for power and drive ability Yes you can save a few bucks but may or may not get more power and may sacrifice drivability. If you buy the 430 you'll eat up most of the 1400 saved once you change the cam and tune. A bigger issue is you will lose the 24/5000 warranty.
Guys are seeing close to 550 on dynos with long tubes with the LS3/525 engines.
If your looking for more then 525 I would consider building an LS2 stroker with LS3 cnc'd heads or stepping up to an LS7. Either way you'll drop more $ into them then you will the GM crate motors.
Old 12-02-2015, 10:57 AM
gnx7's Avatar
gnx7 gnx7 is offline
If you go on Corvetteforum.com there are a number of LS7's for sale (pullouts) for around $10K. A brand new one with ported heads etc zero miles for $11K. I know that is more than an LS3 cost... but you are getting 50 cubes+ and most of those have upgraded cams/springs, ported heads etc.
There is also one with 15K miles, ported heads/intake, cam, 570rwhp for $8500obo. It is a longblock so no intake.
I'm selling the oil pan adapters to make lines and run the dry sump tank either in the engine bay or trunk. You can buy a used dry sump tank off of eBay or RacingJunk for a couple hundred $'s. LS7 intake manifolds are around $250 or less (without TB or injectors). You can run LSA (56#) injectors and the rail is around $160 new or you can run Holley billet rails $120 and build them out from there.
I ran my LS7 with Holley HP Efi and a cable TB. I kept the dry sump. With only a cam upgrade and headers/tune it made 520rwhp/472rwtq and did 138mph in the 1/4. 3000lbs with driver. 50 cubic inches does wonders for torque in the low/mid range.
The main issues with LS7 motors is the valve guides wear out prematurely and the factory exhaust valve is prone to failure.... as long as those have been addressed it's a great motor.
Old 12-02-2015, 04:04 PM
Vega$69's Avatar
Yep the LS7 is more $$$ and in stock form only 505 hp compared to the LS3/525
Also if you run LS7 you will need to either run the dry sump system which will cost a fair amount and find a place to put it. Or like I do on mine convert to wet sump (costs about $600 or so)
Old 12-02-2015, 04:34 PM
How were the ls480 engines for power and street manners vegas?
