Old 07-10-2006, 08:28 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Default Are the SBC's and the BBC's Dead?
Hello:
I'm still trying to catch up with new technology so please bear with me.
After reading over and over about the popularity of installing the LSx engines, I'm begining to wonder:
Are the LSx series of engines wildly popular because they are a significant bang for the buck, or are they currently popular because they are the, "In" transplant to have in a modern PT car?
Please help me shed some light on this.
Thanks for your patience.
tyoneal
Old 07-10-2006, 10:32 PM
Steve1968LS2's Avatar
Originally Posted by tyoneal
Hello:
tyoneal
No, 99% of all Chevy engines out there are SBC and BBC engines. As popular as LSx stuff may seem it's still in the tiny minority. They are popular more than just because they are the "in" transplant to have but because they are a huge technology leap over the older SBC and BBC engines.
15 years ago what would it have cost to build an all aluminum SBC? How about with fuel injection? That technology is relatively cheap. PT cars like the LSx stuff due to it's lightweight that pays big dividends in handling.
Still, nothing beats the brute force of the BBC and the massive amounts of torque that can be had (and the wow/coolness factor). Also, nothing beats the cheap and easy performance of the SBC and the vast supply of inexpensive parts for it. Both of those engines will be around forever.
Old 07-11-2006, 11:05 AM
rocketman's Avatar
The Lsx enigines are popular,But the SBC/BBC combo is still out there.The down side to the Lsx package is the ecm to run it,And they are a little more to build.If you are starting from scratch a Ls wouldn't be a bad option,but I don't see any reason to change to one,Like many guys do,There's really no power differnce in them,just have the "latest craze".
Old 07-11-2006, 11:21 AM
nitrorocket's Avatar
The real key to an LSX motor is the power. How much does it cost to build a sbc to 400+ hp at the crank with fuel injection and have it live 150K miles???
An lsx can be had turn key for $3-4K. That includes 400-500 hp, aluminum block, fuel injection, and a far more solid foundation for a future performance buildup.
I have built 5 SBC's for my car over the last 12 years, I went LSX due to a lower cost and increased performance. Heck I am using the complete stock LS1 fuel injection and making a reliable 1000 hp with just good rods, pistons, and turbos. You just cannot do that with a mostly factory SBC or even BBC for that matter.
Twin Turbo LS1 '71 Chevelle
1000 hp 93 octane street car
6 speed
Old 07-11-2006, 07:31 PM
rocketman's Avatar
The standard Ls1 is not 400 hp.A standard ls1 is 345hp,A ls2 is 400hp,A Ls6 is 405.
Ls1 is 3-4 grand
Ls2 is 5-7 grand
Ls6 is 7-9 grand
Ls7 is 13-15 grand
Yeah they are replieable,but any engine an be built that way.
You can add turbos to almost anything and make 1000 horse.So yeah it's cool,but that turbos set-up will need freshed every 30-40 thousand miles depending on abuse.
Nitrorocket did you try a SBC turbo combo 1st.to compare them?So how do you know that it couldn't be done.
Just curouis
Old 07-11-2006, 07:45 PM
tyoneal's Avatar
What is the best (Easiest, most durable, least expensive) platform to build to 600-800 reliable horsepower?
How would it need to be configured?
Any idea on cost to build?
Cost to install. (Plus things needed to make the install)
Thanks,
tyoneal
Old 07-11-2006, 08:02 PM
I will ramble a little.
I am speaking from experience, not hearsay. I have built many high dollar SBC's. It cost big money to build one that will last with big power #s(800-1000 hp). I also used to be in the buisness of selling used LS1's. I have sold them for profit for as much as $3500 and as little as $2400 turnkey. I bought them for far less, you just have to keep an eye open, but that is besides the point.
I am not saying big power cannot be made with a sbc. Heck there are 2000 hp SBC's.They can make equal power, but not at the same cost for the 1000 hp level.
The reason i went to an LS1 last year is I wanted a turbo setup. The "bullet proof" motor I had, plus the turbos would have been too much money and I was already afraid of hurting the engine. I was able to buy an LS1, build it, and twin turbo it for the cost I sold my N/A motor for!! That is why I did not turbo the SBC.
I like the huge weight off my chest knowing if I hurt this motor, they are a dime a dozen, for instance, I break a rod and take out a block and crank. An LS1 block and crank can be had for $500, where as a sbc aftermarket block and crank to handle this power would cost about $3200.
I am now really PRO-LS1 because of the basic reasons of, low cost, fuel injected driveability and mileage, and the aluminum block!! I think the aluminum block is the best part, I always wanted one, but at $3500+ for a aluminum dart block, I could not afford that in my whole life!
Also, the rating on the ls1's is a little low. Stock ls1's are dynoing 350 rwhp. That is what they are rated at at the crank, I don't know what is up with that, but they make much more at the crank then they advertise.
Again, I love SBC's, I have alway stuck by them, but since I went LS1 and had such huge luck with power and low cost, I personally would never go back. I built a ls1 that will handle 1000+ hp for only $5500, That is just too cheap!! Yes, I have turned into a tightwad!
6 speed
