Old 12-28-2015, 09:26 AM
Mr.VENGEANCE Mr.VENGEANCE is offline
Default My McCleod Throwout Bearing is leaking BAD what other would you use to replace?
So yea.. my McCleod Throwout is leaking badly with my Ram Clutch.. and I readup on them and they are notorious for leaking.
What company do you reccommend that I replace it with?
Any help would be greatly appreciated!
Thank you guys!
Old 12-28-2015, 03:45 PM
angrybird angrybird is offline
Tilton 6000
Old 12-28-2015, 08:47 PM
I was looking at that..
Old 12-29-2015, 05:10 AM
Vega$69's Avatar
Vega$69 Vega$69 is offline
I've run McLeod 3 times without issues. Do you have a stop on the clutch rod the the cylinder?
Old 01-04-2016, 08:56 AM
gmorris gmorris is offline
I had issues with Macloed bearings in the past as well. I went with an external slave setup from forte's because I was sick of dropping the tranny to change leaking bearings!
Old 01-04-2016, 12:33 PM
trevor572 trevor572 is offline
Hi. I'm about to fit a mcleod master and slave cylinders along with their firewall kit, I would really appreciate it if you could post some details or pictures of the stop you spoke of, sounds like a good idea and I would prefer not to have issues further down the track. Cheers Trevor.
Old 02-09-2016, 05:09 PM
DT69Cam DT69Cam is offline
Default McLeod
I just ordered their firewall kit for now. Will order the TOB later. I have read a number of leaks associated with the TOB and it does make me question if I should purchase another unit.?
69 Camaro Convertible (LS3/TKO in the works)
