Old 01-31-2016, 04:35 AM
71RS/SS396's Avatar
Default New Trunnion Upgrade
We've seen the early stages of bearing failure with the popular trunnion bearing upgrades with any mildly aggressive cams. I seen the bearings start to deteriorate in as little as 4,000 miles so I've been looking for alternatives.
Straub Technologies has announced a bushing solution that I think has promise as a better solution for durability. I just sent a set of rockers to CHE Precision prior to finding the ones from Straub. I will use the CHE bushings in my wife's car and ordered a set from Straub for mine so we can compare the 2 to see if there's any difference. CHE charges $420 for the bushings and the installation and will not sell you the bushings to install yourself. Straub will sell you the shafts and bushings at the cost of $159. http://www.straubtechnologies.com/ls...trunnion-kits/
Old 02-07-2016, 09:30 AM
jwcarguy jwcarguy is offline
Banned
Good info!
Thanks for the heads up on another option out there
Jeff
Old 02-07-2016, 01:26 PM
Tim --- I follow a machinist / engine builder on Instagram @Steeldustmachine
and they found that factory rockers are way off on the face/rocker tip. He's been offering a set that he trues up. That rocker tip being off side to side probably puts a lot of pressures were they don't belong!
Old 02-09-2016, 03:31 AM
71RS/SS396's Avatar
I don't doubt he's finding some things but here's a pic of a trunion shaft out of an engine with 4,500 miles on it. If the rocker were severely tilted you would see damage close to center on one bearing surface and the other bearing surface would be damaged out near the retaining clip. In the pic the one side is damaged worse than the other but both sides are damaged near the center of the shaft.
Old 02-17-2016, 03:34 AM
71RS/SS396's Avatar
For anyone that cares and is still following this thread. I received the Straub trunion upgrade kit, the shafts are REM finished and have oil groves machined in them, the shafts also appear to be harder based on a simple test we did using a spring loaded center punch.
Old 02-17-2016, 03:32 PM
Tim, do you know anyone who is using these already and what they think of them?
Old 02-17-2016, 05:13 PM
glassman's Avatar
glassman glassman is offline
I just upgraded my trunnion's along with the purchase of PRC' heads n Comp cam.....Cant remember the brand trunion, but went with the "C" clips.
Will keep an eye out for this week spot, thanx,
Mike
Mike
Old 02-17-2016, 07:21 PM
Che70velle's Avatar
CHE has been doing this with bushings for 5 years, so it's not a new thing for LS engines. I ran bushings in my shaft rocker SBC dry sump race engines 15 years ago. The technology is sound, so don't shy away from it...however...this is really only necessary for "all out race applications" or a build where the owner is always up around 6k to 7k rpm, with a valve train that is brutal. The typical aftermarket bearing trunnion upgrades are fine for the average street car that sees an occasional blast. I did my trunnion upgrade, with bearings, at 80k miles, and my shafts were perfect, with no wear.
Thanks Dad!!
Old 02-18-2016, 03:53 AM
71RS/SS396's Avatar
I don't personally know anyone that are using them but have read some posts on forums from folks using them with positive feedback on the CHE ones, the Straub kit is new and much more affordable.
I don't think this is an "all out race" problem, if you track your car with any regularity you're going to eventually have this problem. That shaft I posted in the pic of has 4,500 miles on it with mixed street and a few track days. The cam is in the .620 range which is pretty common nowadays, so it's not some monster crazy cam with crazy spring pressure. The aftermarket needle bearings are narrower than the factory bearing so it has less area to spread the load out. I think the bearing is where the problem lies since it looks just as bad, if not worse than the shaft. I've tried pretty much every companies needle bearing upgrade kit out there, they all eventually fail. The bearing used is the same regardless of whose kit you buy which is where I believe the problem lies. I've sent the shafts out to be Rockwell tested and some are harder than others, there's also some that have different designs on the shaft to feed more oil to the bearing.
Now that Straub has a bushing kit that's the same price ($150) as the needle bearing kit I see no reason to not go that direction if you're going to do a trunion upgrade. The CHE upgrade is expensive ($420) and you have to send them the rockers or exchange yours, they will not sell you the shafts and bushings. I'm going to try both companies and see if there's any difference in durability.
I'm not selling any of this stuff, I'm simply sharing the info from my own experience, everyone should make the choice they feel most comfortable with.
Old 02-24-2016, 03:22 AM
71RS/SS396's Avatar
Here's my first take on the comparision between the 2 bushing upgrade kits:
The CHE kit uses a spiral lock clip instead of a snap ring like the Straub kit.
The CHE trunion shaft is .709 vs .625 for Straub but this does make the bushing thinner than the Straub.
I still like the fact the Straub kit has oil grooves in the shaft
Both kits rotate very smoothly with vitually no drag, I honestly cannot tell the difference in resistance between the bushings and the needle bearing, but this is with no load so that could change.
When we pressed the bushings in flush with the outside of the rocker on the Straub kit there was .025" of axial movement of the shaft, so we machined up a fixture with a .01" step in it to press the bushing past the outside and closer to center which gave us .005" axial play and also makes it so the snap ring isn't trying to control the axial movement. I would like to see this bushing about .10" wider than it is but it's not the end of the world the way it is.
