Old 02-22-2016, 09:47 AM
RocketsGarage's Avatar
RocketsGarage RocketsGarage is offline
Default Power steering bother
I've been fighting with a power steering system on a '68 Camaro build for awhile now with no luck. I'm running out of ideas. The system involves a Vintage Air front runner serpentine system for a big block, DSE rack, remote reservoir & braided stainless lines with steel hydraulic AN fittings. 275/18" BFG Rival tires.
The system bleeds out fine, has correct pressure & no leaks that I can find. Once the car is on the ground & warm the power steering pump starts to get noisy & fluid begins to get foamy. The steering performance is ok just don't like the noise etc. The customer plains to do a little light autocross every once in awhile & I don't want problems.
Idea's for a fix?
Old 02-22-2016, 09:55 AM
dontlifttoshift's Avatar
Which reservoir are you using?
Donny
Old 02-22-2016, 11:09 AM
Blake Foster's Avatar
and which pump? Vintage air uses the Mavel pump and in our experience with big tires the pump cant handle it
Blake Foster
www.speedtechperformance.com
Old 02-22-2016, 11:34 AM
It's a KRC reservoir & a GM type II pump, tough stuff brand maybe? I've herd the big tires can be an issue with pumps.
Old 02-22-2016, 05:05 PM
David Pozzi's Avatar
How big is the hose from tank to pump inlet? It needs to be -10 minimum, AND have no restrictions or sharp edges or you can get cavitation & foaming.
In the photo, it looks small.
http://www.PozziRacing.com
Old 02-22-2016, 05:12 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
You're just a problems solver aren't ya.
Curtis
Old 02-22-2016, 06:48 PM
It's hard to see from the picture but it's a -10 from the reservoir to the pump.
