Old 03-09-2016, 11:55 AM
lawrenq lawrenq is offline
Default Mini tubbed 70 Chevelle
I plan on running a 20x12 wheel on the rear of my Chevelle with 335/30/20 tires. I'll be using the ABC performance mini tub kit and my inner wheel wells are stretched two inches.
Anybody here running something similar, I plan on lowering the car two inches but I'm not going for the tucked look. I'm also running UMI upper and lowers control arms up front and I would like suggestions on the biggest wheel that I can fit upfront. From my research it seems like a 19x9 wheel will fit on a 275 wide tire.
Old 06-23-2018, 08:08 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
How's the car coming along? Did you ever mini-tub it?
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 10-10-2018, 08:49 AM
The car is coming along well, but I still haven't decided on wheels yet. I have a set of 345/30/20 tires that I want to make work. Here is a picture of the tires mocked up in the opening.
Old 10-10-2018, 10:19 AM
With some massage work to the inner fender , a splined sway bar and the right wheel offset you can fit a 315 up front. Call tony at abc. He will fill you in .
