Old 05-17-2016, 08:28 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Default Fox Body build
I've had this build going for quite a while so I won't bore everyone with every picture I've taken over the last 4 years .
I'm building this car for a fun street cruiser/autocross car. As of now, this is the parts list.
- 331 shortblock w/ AFR 195 heads (58cc ~ 10.5:1 CR)
- D&D Performance TKO 600
- 31 spline rear with 3.73 gears
- Ridetech Level 2 coilover package, UPR tubular K member, Stiffler's FIT system, bigger sway bars
- Baer T4/SS4 brakes; 13" rotors in front, 12" in the rear, Baer Remaster
- Wolfe Racecraft 6 point roll bar
- Corbeau FX1 seats, Ridetech harnesses
- Dakota Digital VHX instrument cluster
and some other random parts.
Right before tear down, just for a reference back!
Getting rid of the terrible wiring in the car and cleaning up the engine bay.
and it begins
The Following User Says Thank You to Josh@Ridetech For This Useful Post:
syborg tt (01-15-2019)
Old 05-17-2016, 08:51 AM
Dyno video:
Made 364rwhp/354rwtq
https://www.youtube.com/watch?v=tfvbFjNWcyw
Old 05-17-2016, 11:12 AM
SBDave SBDave is offline
Nice car! I've always thought these looked mean.
What's the deal with all those tubes connecting what I assume are subframe connectors and the rockers? I've heard these cars aren't very stiff... is that all custom or from a kit?
thanks for sharing!
Dave
Old 05-17-2016, 12:01 PM
thanks for sharing!
Dave
Thanks Dave!
That piece your seeing is the Stiffler's FIT (fully integrated technology) system. It's a combination of a couple pieces. There are subframe connectors, pinch weld supports, and the web bracing helps tie it all together. The combination of these parts and the cage really tighten the weak parts of this car up. After the first couple hundred miles that I've put on it, I'm pretty amazed with how tight the car is but more happy with the way that it rides. It's basically like driving a go-kart that rides nice!
Old 05-17-2016, 05:45 PM
Nice work, Josh!
Old 05-18-2016, 06:19 AM
Nice work, Josh!
Thanks! I need to post up some of the actual build progress pictures. There are a ton of things I left out but it would've been a couple hundred pictures to upload!
