Old 05-23-2016, 11:43 AM
Ben@SpeedTech's Avatar
Ben@SpeedTech Ben@SpeedTech is offline
Default Widened Camaro front inner fenders available!
Hey All-
To go along with our new ExtReme front subframe we are now offering widened front inner fender wells to accommodate the wider 315mm tires and huge steering angle. These tubs have a lightweight and sturdy fiberglass construction and a semi gloss black gel coat finish. Check 'em out by Clicking here!
-Ben, Creative Director
Old 05-23-2016, 04:55 PM
Jr's Avatar
Jr Jr is offline
Who's making them...?
At $1100... Damn
Old 05-24-2016, 07:33 AM
Blake Foster's Avatar
At $1100... Damn
We are having them made for us.
Is 1100 good? Consider how long it will take to make a set? we figured it is minimum 40 hours to build a set of inner tubs and have them finished to this level, so shop rate even at 75.00 hour is 3000.00 makes 1100 a good deal.
Have a look at the other ones that are not available. They start at 1300.00
Blake Foster
www.speedtechperformance.com
Old 05-24-2016, 08:26 AM
HotRod68Camaro's Avatar
HotRod68Camaro HotRod68Camaro is offline
Would these fit with a stock subframe? I'm asking because it looks like the fender side is more vertical. Are they made to work with a rolled like or could the lip be rolled with the fender? I'm not sure how that would work with fiberglass.
Kyle
Old 05-24-2016, 09:59 AM
glr0212 glr0212 is offline
can something like this not be molded or stamped?
Old 05-24-2016, 11:42 AM
considering the Anvil Fiberglass is $1300, these are not that far off. I imagine as they start moving they should come down a bit. Somewhere in the Slosh tub price range. The more you make the better pricing can be.
Old 05-24-2016, 03:19 PM
well they are molded. they are molded fiberglass.
I guess you could stamp them the dies would probably cost 50,000 to have made. and then the price would be 2000 a set.
that is 50,000 for EACH specific part you make. Think about the DSE wheel tubs that no one has a problem paying 400.00 for and they are 2.00 worth of material. and still 30-40 hours to install on top of that.
Blake Foster
Old 05-24-2016, 03:16 PM
we have not tried, the tub is wide to the inside to allow for tire turning clearance and the stock sub would be the limiting factor. I don't think you would gain anything with these.
Blake Foster
