Old 06-10-2016, 01:20 PM
Ben@SpeedTech's Avatar
Ben@SpeedTech Ben@SpeedTech is offline
Default Speedtech's new 3rd Gen Camaro suspension
Hey everyone, more great news! This 91 Camaro RS followed us home a couple months ago...
These cars have a great out of the box performance handling platform, but since we like to play so much, can't leave well enough alone and want to make everything better, we've decided that adding 3rd gen Camaro suspension to our line up was in order. We're anxious to see more of them competing in CAM and the big Pro Touring events, and we've got 3 steps on the R&D board to get things rolling.
Step one is to develop a bolt in performance suspension system including lower front control arms, a better and adjustable front strut, Articulink rear trailing arms, rear coilover conversion, and upgrade it to our better Torque Arm. We're not reinventing the wheel here, just making it much better. Some of these parts are currently already in pre production.
Step 2 is to develop an LS/T56 swap kit. Our RS sports a V6 with a blown head gasket, so naturally it will likely get a 525+ hp LS3 crate engine backed by a T56 Magnum to take it's place.
Step 3 is the real good stuff! For those that want to play with the big boys we'll be developing a new ExtReme front suspension clip that will eliminate the struts and use the same all new suspension found on our new ExtReme 1st and 2nd gen Camaro subframes! This is the most forward thinking and advanced geometry and capabilities available, better than any other Pro Touring suspension currently on the market. Part of the parameters for all ExtReme suspensions is to have a super low ride height, more available suspension travel, fit 315s under the fenders while maintaining 30+ degrees of steering angle, and have geometry that maximizes tire contact on all wheels while cornering.
I found this pic of a nice slammed IROC on the internet. Imagine this stance with 315s tucked underneath all around and a suspension that sticks like a full bore race car. Now this is gonna be cool!
We're pretty excited about this one, tell us what you think!
-Ben, Creative Director
Old 06-10-2016, 05:43 PM
Musclerodz's Avatar
I'm so ready to have another 3rd gen.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-11-2016, 04:16 PM
James OLC's Avatar
As I suddenly seem to have some of these around this house I will be watching your development program with interest.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 06-11-2016, 11:12 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
I had an '84 Trans Am for 19 years, and I miss that car. It would be fun to have another one day, and having a good suspension system available to improve handling and fit wide wheels would be great. I wouldn't prioritize slamming it per se (with just a 1" drop on my car I had enough trouble with speed bumps and curbs) I'd focus on handling like it's on rails with big meats and not compromise the steering.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 06-12-2016, 12:42 PM
Ron Sutton's Avatar
Hey Guys & Gals,
Just chiming in to let everyone know this new 3rd gen F-Body clip has the same optimum geometry & set-up I designed for all of the Speedtech front clips & full chassis. Although each front suspension was optimized for the application, this one is very similar to the 1st & 2nd gen clips.
Video for RSRT Designed Speedtech eXtreme Subframes & Chassis
To watch this In-Depth Video on YouTube ... Click HERE.
New Speedtech eXtreme Front Subframe & Suspension Package
New Cutting Edge Design Includes:
  • Ron Sutton Race Technology geometry built-in.
  • Strong Box type laser cut and jig welded construction - reduced weight over factory subframe.
  • Special subframe width & shape allowing 315 front tires.
  • Next-Gen ATS 7075 Forged Aluminum Spindles.
  • High-Ackerman steering arms for ATS spindles.
  • C7 heavy duty bearings & hubs.
  • Speedtech high clearance upper & lower tubular control arms
  • Upper control arms feature additional caster adjustability.
  • Control arms powder coated gloss black and fully assembled with Delrin bushings.
  • 3-piece Speedway Engineering sway bar – Choice of rates from 400# to 1300#
  • Sweet racing DUAL POWER rack & pinion steering.
  • Accepts LSX engines with Speedtech fabricated oil pan and motor mounts.
  • Adjustable engine frame stands allows 3/4" fore & aft range.
  • Fully adjustable rear cross member fits all GM transmissions as well as T-56 and TKO.
  • Factory alignment holes offer ease of aligning frame to body and bumpers.
  • Mounting hardware, instructions, and custom alignment specs.
  • Comes bare. Powder coat options available.
  • Built-in tow/tie down hooks eliminate strapping around painted frames.
  • Ridetech single adjustable coil-over shocks, including delrin thrust washers & adjusting wrench.
  • Hypercoil coil-over springs – Wide choice of rates.
Available as Bolt-In Clips for:
67-69 GM F-Bodies Camaros & Firebirds
70-81 GM F-Bodies Camaros & Firebirds/Trans Ams
68-74 GM X-Bodies Novas, Venturas, Skylark & other GM X-Body Cars
and now ... 82-92 3rd gen F-Bodies: Camaros & Firebirds
OPTIONS:
• Powder Coat Subframe – Flat Black
• Powder Coat Subframe – Semi-Gloss Black
• Powder Coat Subframe – Gloss Black
• Powder Coat Subframe – Gun Metal Grey
• Powder Coat Subframe – Silver
• Billet Aluminum Body Mount Set
• Engine Bay Round Tube Chassis Down Bar Supports
• Double Joint Steering Shaft Kit
• LSx Engine Adapter Plates
• Speedtech 1 7/8" LSx Headers, Mill Finish
• Speedtech LSx 1 7/8" Headers, Show Polished Finish
• Ron Sutton Tailored Suspension Tech Service #40STP
• Ron Sutton Tailored Brake Tech Service #29
• Ron Sutton Secret Sauce Digressive Track-Star Valving added to Ridetech Single Adj Shocks
• Ridetech Triple Adj Shocks w/Digressive Track-Star Valving
• JRI Shocks w/Digressive Track-Star Valving in Single, double or triple adjustable
For more information ... OR To Place Your Order ... Contact Ron Sutton Race Technology:
Phone: (916) 834-8051
Email: [email protected]
Address: 11374 Amalgam Way, Suite K, Gold River, CA 95670
Website: www.RonSuttonRaceTechnology.com
Old 06-12-2016, 12:45 PM
Ron Sutton's Avatar
Hey James,
The geometry on this clip is in line with my TA2 race clip, except the Speedtech clip puts the roll center in the optimum spot regardless of how much you travel the front end. This is the first time I've achieved this ... so this clip would work awesome for any setup a person chooses. So if someone runs a stiff spring set-up & only travels the front end around an inch ... the roll center is at 2" above ground, which is optimum for that setup. If they high travel the front end ... say 3" ... with soft springs & a larger sway bar ... the roll center is at ground level ... again, optimum for that setup. in moderate travel ... around 2" ... the RC is at 1" - perfect.
The dual power Sweet rack will handle the load from the high grip suspension & 315 front tires (TW200 or slicks) with ease. No rebuilt $300 OEM racks here. This puppy cost almost $1000, but it is built to take the loads we're creating these days.
I forget if you have my AutoX-Star or Track-Star valved Ridetech shocks on the OLC Camaro. But these clips are available with my Track-Star "secret sauce" digressive valved shocks in single or triple adjustable.
* Quick side note: On Friday May 27th, I went shock testing with a championship GT team that races in the Western Endurance GT car series at Buttonwillow (because it's a bumpy track - perfect for shock testing). They ran a best of 1:49.9 with their Bilstein race shocks. Then ran a best of 1:46.8 ... 3.1 seconds quicker ... my Track-Star valved Ridetech triples. The driver couldn't believe the grip increase. These are the same shocks I make available to the Pro-Touring world, and are optional on this Speedtech clip.
All the geometry on this Speedtech ExtReme front clip is spot on:
* Roll Center location & dynamic migration - Optimum grip
* Bump steer changes only .001" in 3" travel
* Anti-dive is 40% - allowing us to run softer springs & still achieve a low roll angle
* Ackerman is 100% - Creating optimum slip angle on inside front tire
* Dynamic Camber/Caster creates optimum contact patches on BOTH front tires
* Jacking effect is Nil - allowing softer springs & still achieve a low roll angle
* Front Sway bar rate range is from 400# to over 3000#
This would be extremely racy for your new 3rd gen.
Old 06-12-2016, 06:34 PM
James OLC's Avatar
Thanks Ron - we can chat more (I owe you a call as it is).
The '89 has been evolving well but the last weekend out was a tad cold and wet:
This should be a fun week though, I sourced a hood, fenders, and quarter panels from an IROC series car - they should finally be here this week (along with a new set of Toyo RR tires).
Suspension is about "maxed" out for the "stock" design so I am always looking at new options.
James
1969 Camaro - Dusty
Old 06-13-2016, 08:02 AM
Thanks for chiming in Ron!
That's a pretty sweet sleeper there Tuske! I think another should definitely be on the build list!
Looks like fun James! "Suspension is about "maxed" out for the "stock" design so I am always looking at new options." We anticipate being able to help with that!
Old 05-20-2017, 12:17 AM
cjsgarage cjsgarage is offline
We've a got a pretty well handling one as a sort of sponsored shop project.
Blake and Ben:
These cars would need body modification to fit the 315s in the back. The tubs need some alteration. We have 275s all the way around, no rubs on a factory body. Actually, they may need modification in the front, too. The wheel wells may not be wide enough to allow a 315 to sweep. I know we're dangerously close to rubbing the body kit wit our 275s.
Also, we dropped an LS and t56 into this car. We used the 4th gen Camaro rear end and torque arm along with the swap. Bolts on. The trans mount is fabbed, engine mounts are from Hawks Third Gen.
Exhaust clearance is a big issue on these cars. There's not room to go duals over the top if you have the panhard bar in place. We went with a Fays2 Watts link and elected to dump the exhaust before the rear end. In factory form, they have a weird pocket under the passenger front floorboard where the catalytic converter lived.
After that, there's no reliefs in the floor to fit exhaust. Adding a torque arm further cramped our room.
But just so you know, a 4th gen tank will drop in place of the third gen unit and you can sorta reuse most of the fuel lines as they are. Makes that bit a no brainer. Also, the pedals from a 4th gen will slide in place of the third gen stuff.. so you can use the stock clutch master.
I like wiring. No joke.
Old 05-30-2017, 08:02 AM
Great info, thanks!
