Old 06-28-2016, 10:34 AM
Decline Decline is offline
Default GM type II pump choices?
I got the specs from Morrison for the rack,2gpm 1100 psi
Narrowed down my choices to Turn one Jones racing and Sweet. Also leaning towards integral reservoir for easier cleaner install
anyone have experience with any of these manufactures, do the caps leak?
The main thing I am trying to avoid is the "weeping" issue I've read about from DSE integral style. Also thinking of going plastic Rez since it should absorb less heat
as for the pumps themselves the jones and the turn one are around the same price and the sweet is about $100 cheaper. No company's specifically say what they do to the pumps to make them better except jones who claims they CNc them to their specs and dyno them on a flow bench to confirm the rates. Plus jones is by far the most "bling". All the parts look super nice so I'm leaning towards them right now
thoughts opinions?
Old 06-28-2016, 11:38 AM
Blake Foster's Avatar
thoughts opinions?
we have used both Jones and Sweet. Drive Junkie uses Jones, jones is pretty specific on some of the requirements don't spin it over 7000 use synthetic fluid with a cooler. Jones is probably the better of the 2
Blake Foster
www.speedtechperformance.com
Old 06-28-2016, 01:08 PM
Thanks for the reply.
I already went ahead and purchased the Jones integral setup from the man himself. The fact that he will build it to my slightly irregular specs and provide a flow sheet to confirm the numbers is worth the premium to me.
I was not aware of the RPM limitation. While that currently isn't a problem with my small block, it's good to know for my "someday" LS swap.
Also I will be adding a setrab 13 or 16 row stacked cooler. Lines and fittings are going to come from Brown and Miller
My DSE rack already has a nice feel to it, hoping this improves it even further since it will finally be getting the proper flow from cool high quality fluid
Old 06-28-2016, 02:42 PM
the 7000 rpm is the PUMP speed not the engine speed. We use a 5.5" crank pulley and a 6.5" PS pulley to keep it down when the LS is at 7300
most front drives use a larger Crank than PS pulley which over drives the pump. some can get as high as 8500 rpm with 6500 crank rpm just something to check
Blake Foster
Old 07-02-2016, 06:59 PM
Pump just arrived this afternoon. Man are these parts pretty, the fact that they work so well is icing. After seeing how nice everything is I might have to pony up later for the aluminum reservoir to admire more of their craftsmanship. I mean c'mon, they laser etched the logo into the port caps.
Old 07-05-2016, 09:08 AM
yea that you just throw away!!
Blake Foster
