Old 11-09-2016, 11:54 AM
Doug1's Avatar
Doug1 Doug1 is offline
Default repairing plastic channel on rear interior panel
what will hold this plastic together from behind? The cracks are along the curved piece that folds over the metal seam that you see when you open the door. I need something thin and strong that will be strong enough to hold it together from behind without peeling off. I can use some sort of fabric glued to the inside of the plastic channel but the glue needs to really stick to plastic and not peel off.
Old 11-09-2016, 04:39 PM
98ssnova's Avatar
98ssnova 98ssnova is offline
Can tou put a metal chanel in the under side then cut out the bad part and re glass it? Just a shot in the dark? Good luck
