Old 03-24-2017, 07:10 AM
SSLance's Avatar
SSLance SSLance is offline
Default Need input on crankcase evacuation remedies
Some basics of my setup first:
Its a 10.1 cr 383 SBC, 0.534/0.537 lift cam that makes 18" vac at idle, Fastburn heads, dual plane intake and a quadrajet, 525 ft lb at 4700 rpm, 467 hp at 5400 rpm. I street drive the car as well as race it on autocross and road course events 15-20 times a year.
During it's first season, I noticed significant oil blow by coming out the breather on the pass side valve cover, the driver side VC has a PCV valve plumbed to the carb. I'm investigating cures ranging from a engine driven Vac pump setup to just a catch can with a breather. My main concern is capturing the escaping oil, but I'm trying to figure out if putting a complete crankcase evac setup on the car would be a worthwhile investment.
I just started reading about the vacuum pumps yesterday and a few things concern me. It appears that they are mainly used in drag race applications to free up a few horsepower and to help the rings seal to make a little more power. I also read that the pumps need a little bit of oil to go thru them to keep them lubed.
I'm not really trying to eek every last little bit of power out of the engine and it gets street driven regularly...will a vacuum pump survive under just regular driving...not getting rung out on ever single run like a drag race application? And is it worth the cost (like $750-1000) and the hassle of mounting one and trying to run a belt to it for my application?
Or should I just plumb in a catch can tot he pass side valve cover and call it good?
Now onto that part... Is there a way to adapt a -12 type fitting to my existing breather hole in my valve cover or is my only option to have a fitting welded to the valve cover somehow? I'm not opposed to modding them but if I didn't have to it would make this more of a home remedy type job.
Here are some engine pics for reference...as you can see there is a lot going on under there so space is at a premium.
I welcome any ideas from those with experience in this area.
Lance
Old 03-24-2017, 08:04 AM
Matt816 Matt816 is offline
I'm not sure if this is a cure or something you've already read about, but I just installed a ME Wagner duel flow pcv valve on basically your same motor. I was noticing blow by and gaskets weeping oil. Once dialed in per their instructions it appears the weeping has quit and oil blow by has been solved too. They suggest an oil catch can to be plumbed inline. I picked up a moroso can but haven't plumbed it because I'm not sure I need it. Time and miles will tell if I do I guess. If you haven't looked into them, maybe see what you think.
Old 03-24-2017, 09:17 AM
SSLance's Avatar
Thanks Matt, that looks interesting... What did you use on the other valve cover, a breather of any sort?
I think my issue is compounded by the type of driving I do on track, mainly on autocross runs. Multiple WOT blasts immediately followed by short closed throttle blades...then WOT once again. I think my current PCV setup just can't catch back up quick enough creating excessive crankcase pressure on the WOT blasts.
I don't really care about "pretty" on this engine anymore, I'm more concerned about function. But at the same time I'm more interested in a fix that will work with what I have instead of reinventing the wheel if that makes sense. Some sort of solution that will work with my existing grommets in both valve covers would be ideal for me.
Lance
Old 03-24-2017, 11:46 AM
ADY's Avatar
ADY ADY is offline
I have a similar 383 (think 19" vac at idle) and have a similar breather on the passenger and PVC on the driver and haven't experience any problems after installing a Moroso catch can between the PVC valve and the throttle body. The amount of nasty crap at the bottom of the catch can is surprising considering it was going straight in to the engine before. I remember finding a great site that listed out the different breather setups (NA vs. turbo) that I'll try to find and post on this thread.
Here's what I have:
Breather - https://www.spectreperformance.com/s...aspx?prod=4919
PVC - https://www.spectreperformance.com/s...aspx?prod=4921
Moroso Catch Can - (got it for $39.99 on Amazon, total screw up on pricing) https://www.amazon.com/Moroso-85474-.../dp/B004K9BIY4
-Adam
1968 Camaro SS
Old 03-24-2017, 01:42 PM
l2azorback l2azorback is offline
Default Catch Can
Hello,
I am running a MightyMouse Solutions Catch Can on my 540 BBC. My set-up includes a -12AN dirty side to catch can, and a 3/8 clean side to throttle body with a turbo car PCV valve. This significantly helped my set-up which originally consisted of one K&N breathers on top of each valve cover. Give Mighty Mouse a call, and he can help you with your application. These are very popular for twin turbo LS cars.
www.mmsolutions.com
Regards,
Larry
Old 03-25-2017, 08:40 AM
SSLance's Avatar
Wow!! Thanks Larry, tons of useful information at MightMouse. Here is the correct link BTW if anyone else goes looking for it...
http://www.mightymousesolutions.com/mm-catch-cans
I have contacted them about putting together a custom setup for my application.
Lance
