Old 07-16-2017, 06:26 PM
Default Hot Rod fix or HACK Opinions please
Hi guy need to ask a question. My headers which are already coated and on the car are interfering with my transmission connection to the cable for the shifter. I've been thinking of all kinds of fixes, changing the range shift selector rod to a short one which the valve body has to be lowered to remove a nail which holds it in. ( Not in my range of abilities). Then having a new shift lever made, (which I'm not opposed to)
Then the question Hot Rod fix or HACK
I thought of this a while ago while dealing with my oil cooler lines. space the header out at the head, hear me out!! I could get a header flange and longer, better bolts from ARP and put the flange between the head and the original header flange with RTV or what ever would be best to seal then together and the gasket between the head and header. This would also solve my heat and space problem for the oil cooler lines.
Here is the shifter problem
Here is with the header flange spaced a little over a 1/4"
Here it's about 7/16" spaced
how close the oil line were, they're tighter than they look.
And with the header spaced out.
What do you think? Hot Rod or Hack?
Old 07-16-2017, 07:32 PM
JKnight JKnight is offline
Can you flip the shifter cable bracket over so the bend in the bracket jogs away from the header rather than towards it?
Old 07-16-2017, 08:02 PM
No the lever has holes for three types of transmissions and of course mine is the furthest towards where the problem is, all the way to the front.
It's the top hole (in pic) on the square end which faces forward.
Old 07-17-2017, 04:56 AM
TomM's Avatar
TomM TomM is offline
Looks to me like that is your o2 sensor bung....correct? No amount of spacing will give you the room to clear the sensor. Best thing to do is relocate the sensor to clear...and have the headers re-coated....
The oil cooler line looks fine to mew, you have heat shielding on it.....it should be good...
T,
Old 07-17-2017, 05:18 AM
Tom, that bung will be capped off its already move to the ther side of the header. On the hoses it is so tight we made a sheet metal shield you can feel it touch when sliding in.
Old 07-17-2017, 07:49 AM
TomM's Avatar
I see it now, it's the hose in the back. Can you source a 45 degree fitting to extend the front one down and at an angle to angle away from the rear one?
Something like this.... http://www.jegs.com/i/Earls/361/AT924110/10002/-1
What size are your oil lines?
As for the shifter bracket, I would take a BFH and straighten it out to give you clearance if you can do so.
T,
Old 07-17-2017, 05:56 AM
1Bad68Cat 1Bad68Cat is offline
How about trying to re-bend the bracket? Use a vise/hammer to straighten then make the jog the other way.
Robert Icasas
Projects:
67 Cougar
Art Morrison Sport IFS
3-link Rear Suspension
Coyote w/ D&D Performance Viper t56
Build: https://lateral-g.net/forums/showthread.php4?t=50170
Brother's 1966 Mustang Restomod
Mustang II front suspension
Torque Arm Rear Suspension
Ridetech Shockwaves
5.0 w/ Viper t56
