Old 08-17-2017, 01:47 PM
Jr's Avatar
Jr Jr is offline
Default Baer remaster
Is anyone using baers new remaster setup? I'm thinking about using baer or dse... any feedback would be appreciated.
Old 08-17-2017, 01:53 PM
68EFIvert 68EFIvert is offline
I have one on my shelf that will be going on my Volvo project once the bodywork is done. I can't give you a performance review but I will say it is the nicest MC I have ever seen. Workmanship is 2nd to none.
Old 08-17-2017, 07:32 PM
Jr's Avatar
Jr Jr is offline
Thanks. I hope that someone has some feedback.
Old 08-18-2017, 05:02 AM
69hugger's Avatar
69hugger 69hugger is offline
I have had one on my car for about 18 months. It just works, & looks great. Beautiful machining, excellent anodizing, and easy to fill & check fluid level. It also allows you to use either AN fittings or directly use a flared brake line with the use of an inverted flare "pill". Also has a provision for a proportioning valve to be mounted right underneath it.
Not to mention Baer customer service is (IMHO) second to none.
Hope that helps.
Bill
'69 Camaro / 534 BBC / DSE Built
'67 C10 / LS-3 w/Magnuson / Roadster Shop Chassis (SOLD)
'71 Blazer / LT4 / 8L90 / Roadster Shop Chassis / Ride Tech Air Susp.
Old 08-18-2017, 07:35 AM
andrewb70's Avatar
Here is a review that I did a while back:
https://youtu.be/oPG5GndnA2M
I've been using it on my Cougar for a while now and it works and looks great. I really love that the prop valve can be mounted under the MC, the easy fill, and the fact that I can use either the flare fittings or Banjo fittings.
Andrew
Old 08-18-2017, 02:00 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
We've installed about 10 of them now, all good!
-Dale
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
