Old 08-20-2017, 04:48 PM
DT69Cam DT69Cam is offline
Default TKO, unable to mount to Bell Housing
I just spent all day trying to install my TKO 600 to my LS3 engine. I'm using an LS "621" Bell Housing and I could not get the input shaft to line up in the Pilot Bushing for nothing. Anyone have any ideas ???
69 Camaro Convertible (LS3/TKO in the works)
Old 08-20-2017, 05:44 PM
booah booah is offline
Just had this with a Mcleod set up, twin disc and one disc was backwards. May be the same thing.
Old 08-20-2017, 06:16 PM
Thx for the reply. I'm not sure what the hell the problem is. McLeod flywheel ram clutch. I can't seat the trans to the Bell Housing. Wondering if this BH is that much out.
Old 08-20-2017, 06:38 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Is your pilot bearing correct,not sure but I think there is a couple sizes,good luck
Old 08-20-2017, 07:23 PM
Sideshow Sideshow is offline
if everything is correct. we draw them in with the bolts. I know your not supposed to do it that way but all the ones that we've installed over the yeas have been done that way. just go slow. never had a ear break. btw.
Old 08-20-2017, 09:06 PM
JKnight JKnight is offline
I guess we should start with the simple stuff. You using a clutch alignment tool? Plastic or metal? Mechanical linkage? I had to depress the clutch a bit to get the input shaft to seat properly.
Old 08-21-2017, 12:52 PM
Ear broke off.
