Old 09-15-2017, 07:14 AM
marksawatsky marksawatsky is offline
Default Wheelspin in turns
I have a scratch built autocross car and when I'm turning and accelerating at the same time, it spins the inside rear tire. I have tried an Eaton TrueTrac (Torsen style) and now run a Variloc (clutch style) diff but they both spin the tire. The balance of the car is amazing and I have to be careful I don't make it understeery. I have SLA suspension in front and live axle with 3 link and Panhard out back. I wonder if longer travel shocks out back might keep tires planted. Any suggestions on how to solve this problem? Pictures of the car
Old 09-15-2017, 01:55 PM
andrewb70's Avatar
I am by far not an expert, but if the shock is too short and is bottoming out on rebound, then that would definitely cause the inside tire to spin.
Andrew
Old 09-15-2017, 02:01 PM
Che70velle's Avatar
I was going to say the same thing as Andrew said, but to add as well, are you running a rear sway Bar? I don't see one in the pics. Have you considered a spool?
Thanks Dad!!
Old 09-15-2017, 07:33 PM
I am consulting with Ron Sutton on the suspension but I suspect that getting 7" of rear suspension travel instead of the current 5" (3" compression, 2" droop) will solve the problem. I don't run a rear sway bar any more, balance is adjusted with roll center.
Old 09-16-2017, 05:55 AM
Tony from ABC Performance has a "toed" and "cambered" rear end ,which if I recall he said it helped him drive out of the corners putting down the power. But ....again I'm also not a expert by any means
Old 09-16-2017, 06:14 AM
Smart move.
Old 09-18-2017, 06:02 PM
I talked with Ron Sutton today and he told me to send him the Performance Trends file for my car. Before doing that, I double and triple checked all the numbers and added a few that I didn't have yet. I discovered that my front roll center was 2.5", not 3.5" and that my rear roll center was 14" and not the 10" I thought it was. Also, turns out I have zero caster, not the 6 degrees I thought I had. So, I think I know at least a couple of things Ron is going to tell me to change.
