Old 11-26-2017, 11:52 AM
bergers59 bergers59 is offline
Default Garage clean out-SBC, BBC, Camaro, Olds, Pontiac parts (long list)
Item Location (City/State):Berkeley heights, NJ
Price: listed for most parts, otherwise obo. Looking to clean
Edit: Pictures didn't attach, I have pictures of everything if you need them
Description:
-1st gen camaro steering column(80)
-2nd gen camaro/firebird steering column(with key)(60)
-3rd gen corvette sbc headers, may fit other applications (100)
-sbc valve covers(40)
-1990s SS truck big block valve covers(60)
-Chrome BBC valve covers (30)
-k&n style air filter(20)
-holly 650cfm carb(almost new)(350)
-rally nova/camaro wheel caps(60 for set)
-66/67 gto/tempest hubcaps(40 set)
-miscellaneous gm hubcaps/trim rings(5 each)
-5 quadrajet carbs(40 each)
-cragar wheel center caps(some brand new)(5-10 each)
- 2 two barrel intakes(10 each)
-multiple pairs of sbc exhaust manifolds(10 each pair)
-set of 15x7 JJ rally wheels
-b&m torque converter,car never ran with part on it, part number 20416 (170)
-Date coded drum to drum 67 Camaro rear end 3.55 Posi, differential is cracked between spider gears.
-66/67 GTO front bumper. Has dings but is a good core and is fairly straight
-66 389/421 092 heads 70cc. Correct heads for a 4 barrel 66 GTO
- Rally II wheels with trim rings(looking for center caps, we have them somewhere)
- date coded 66 4 barrel 326/389/421 intake
- 67 GTO center console door. Original wood is in great shape, however there is a chunk of the chrome/metal missing on the side. Would need to be welded or silver soldered then re-chromed.
- high comp 70-71 B.O.P W30/400/455 starter, date coded late 1969
-71 firebird/GTO 37 amp alternator
-78 firebird a/c or defrost 61 amp alternator
- 71/72 B.O.P 400/455 with a/c or HD cooling alternator, also believe it is coded for big block chevy from same years
-64 tempest rear
-64 gto/lemans dash pad
-64 gto doors(need patches)
-64 gto bumper brackets
-64 gto inner wheel wells
-64 gto taillights/gas door
-64 tempest gas door
