Old 12-10-2017, 02:24 PM
garyb garyb is offline
Default Water/Oil Sensors w/Holley Terminator & Dakota Digital
When using both products, do you have two separate sensors for both the water temperature and oil pressure? One pair to the Terminator ECU harness and another pair to the Dakota Digital VHX control box?
Gary
The project my son and I've been slowly working.
'71 Cutlass Supreme
Old 12-11-2017, 12:12 PM
dontlifttoshift's Avatar
dontlifttoshift dontlifttoshift is online now
This should make it easy. http://www.dakotadigital.com/index.c...od/prd1105.htm
Holley EFI Interface Module
From Dakota Digital
The BIM-01-2-HLLY is designed to read the engine information from the Holley Terminator, HP or Dominator EFI kits. The BIM-01-2-HLLY module is a direct plug in using the supplied 2 or 4 pin harness for simple connection to the Holley EFI system.
Not compatible with the Sniper EFI system.
The BIM-01-2-HLLY will collect and output the following information to Dakota Digital Instrument Systems *:
Always available:
Tachometer
Engine Coolant Temp
Intake/ Manifold Temp.
Fuel Pressure
Air/ Fuel Ratio
Please note: Due to the various factory and modified ECM's, additional data add-on's from Holley may be available such as Vehicle Speed, Oil Pressure and Boost. Dakota Digital cannot guarantee the presence or accuracy of the Coolant Temp., Intake Temp., Fuel Pressure Pressure, or Air/ Fuel ratio displays since this is a function of the ECM and matching OEM functional sensors.
*The BIM-01-2-HLLY is designed to decode the information provided by the Holley Terminator, HP and Dominator EFI's (not Sniper) and supply this information to the VFD3 rev. G, VHX and HDX control box instrument systems only. Earlier control boxes (with an aluminum case) are not compatible with the BIM family of Expansion Modules.
Donny
Old 12-11-2017, 05:11 PM
Thanks. I’ll read about it and see how much I need to part ($$) with to make it happen.
Gary
'71 Cutlass Supreme
