Old 04-15-2018, 09:04 PM
Gmachine1911's Avatar
Default DSE engine mount/header question
I'm sure this has been asked before but my searches don't turn up anything...I'm running a DSE subframe with their 1.5" setback LS engine mounts and would like to know if anyone is running the Hooker Blackheart SS long tube headers? I called Holley and they couldn't say with much confidence whether they'd fit or not. The main concern being that in the DSE/Holley setup, the driver side header has a couple of tubes that wrap around the steering shaft and it seems conceivable that, with the setback, it could put the shaft running "through" the tube(s). Thanks!
Old 04-16-2018, 09:59 AM
Musclerodz's Avatar
Don't know who you talked to but they have specific fitments for dse frames. There is a check down box on the first gen header page that lists dse frame or stock frame. I have not used a set so I can't say how well they fit.
Mike Redpath
Musclerodz & Customz
facebook page
Old 04-16-2018, 06:56 PM
Yeah, they do offer fitment for the DSE frame but no one there can tell me if the fitment is for the stock location engine mounts and/or the 1.5" setback mounts. I may just order a set and test fit them and send them back if they don't fit.
Old 04-16-2018, 07:45 PM
Z06vette's Avatar
Z06vette Z06vette is offline
I have those headers, but havent installed them yet. I was told by holley that they would fit either mount. I have run the stainless works headers on my old DSE subframe, and they fit nicely in the stock location, but hit the toeboard with the setback mounts. I wish I could help more, but Im quite a ways away from installing the hookers. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 04-16-2018, 09:14 PM
Musclerodz's Avatar
Get a set of Ultimate mid length headers and not worry about it. I doubt you would notice the difference between the mids and long tubes.
Mike Redpath
facebook page
Old 04-17-2018, 04:34 AM
Scott, thanks for the input! I think I may chance it and see what happens. One quick question, though, are you happy with the quality of rhe headers as they appear? Is there anything you don't like about them? Thanks
Old 05-30-2018, 10:41 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
I have them on my car and they fit. I laid them side by side with a DSE header. They are nearly identical. There were a couple of bends on the DSE header that weren't as tight and may flow marginally better. Quality wise they are a nice part. I sold my DSE headers only after making sure the Holley fit.
Another benefit is that the collector is straight and doesn't have the angled Vband that DSE uses. I have the Holley blackheard header back exhaust that is designed to work with the quadra link. Everything fit with no cutting. The only cuts I made to the entire system were on the tailpipes so they didn't stick out below the rear valance.
Jason Mitchell
1971 Camaro 416 LT1 Project
