Old 05-03-2018, 11:20 AM
Trick-Tools.com's Avatar
Trick-Tools.com Trick-Tools.com is offline
Default MultiTool: The perfect garage grinder
Visit our Multitool store at https://www.trick-tools.com/Multitool-Grinder-Store_852
The popular Multitool belt grinding attachment is also available as a plug and play unit mated to a grinder to get you up and grinding fast! More than a traditional belt sander, this versatile tool has a belt speed of approximately 5,400 surface feet per minute which allows for material removal up to 5 times faster than with the equivalent grit grinding wheel.
In addition to the grinding stone on the left, the Multitool has four different grinding surfaces to cover almost any grinding need. The most used surface is the front contact wheel which has a serrated surface to make grinding and deburring very controllable and smooth. The top platen can be used for straightening or profiling longer edges and the underside of the Multitool has a slack belt area for blending and finishing. Finally, the 7 inch disc on the side can be used with or without the optional miter table for beveling and profiling or final finishing.
Belts change in seconds from grinding, to sand, deburr, or polish. A variety of belts and discs are available for any type of project, see the Accessories tab.
Warranty:
3 yrs on attachment, 2 years on motor
Brycen Smith
[SIGPIC][/SIGPIC]
